Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
Wastegate flapper
- Year and Model: 97 855R
Wastegate flapper
Guys I am rebuilding the head on my 850r and have the turbo off and decided to do it while off. The wastegate flapper appears to be able to move up and down a lot. If not I. The right position it allows a gap at the top or bottom of the port. Is this normal.
- greg850r
- Year and Model: a long list
- Been thanked: 11 times
Re: Wastegate flapper
I don't think it's normal but I can pull one off the shelf tomorrow and check. Meantime, a pic would be helpful if you have the parts on the bench.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
- Has thanked: 52 times
- Been thanked: 201 times
It's normal for the flapper itself to move around a bit when it's open, but when the wastegate is closed (held shut by the actuator) it should seal tight.
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
I will take some pics. I jb welded it. The door fits in a bushing and the bushing moves up and down allowing it to leave a gap. I got the bushing to stop moving so now just the door moves. No more up and down. Just open and close.
Uhhh... sounds to me like you're setting yourself up for boost issues, whether that's over- or under-boosting depends on how you JB welded it.
Pics will be necessary here.
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
Go into "full editor & previrw" or click "post reply" at the top of the thread, then just below the text box, you can select "attachments" and upload it from there.
Otherwise, you can post from an image hosting site like Imgur using the BB code link option.
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
The part that is jb welded is the bushing that the flapper shaft sits in. It is the part that is moving up and down.
Ah, I see. I don't think I've seen that repaired that way before... best bet is to get a new turbine housing.
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
- Year and Model: 2000 V70XC
- Has thanked: 38 times
- Been thanked: 45 times
That's odd. I'd be concerned about that JB Weld inside the housing coming loose and breaking apart after so many heat cycles. Debris like that would not be great to hit spinning turbines and go down the intake into engine.
2000 V70XC - 308,000 miles as of 17 Dec 2020
- 9 Replies
- 1439 Views
Last post by paul c
- 1807 Views
Last post by Switchemlee
- 13 Replies
- 3161 Views
Last post by bmdubya1198
- 14 Replies
- 1624 Views
Last post by Sommerfeldt
- 10 Replies
- 4621 Views
Last post by OJBerkes
