'06 V70 upper shock mounts Topic is solved
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Replacing rear shocks on '06 V70. Should upper shock mounts automatically get replaced. Outside of being torn (mine are not) why would they be replaced. Rubber pliabilty ?
Thanks all. G.G.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I don't think it's needed for the rear ones. Rarely heard of them going bad (the front ones however do). A few tips if you need www.youtube.com/watch?v=f7gsgr9YWy4
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I ordered a set a number of years ago. Removed the old ones which looked perfect and returned the new set as unneeded.
If they look fine keep what you have.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Were your dampers leaking oil?
Or are you doing this to improve the ride in the rear of the car?
I've replaced several rear & front coil springs (they rust & crack over time), but never had a rear damper that was leaking. To me, if it ain't leaking, I don't mess with it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Has thanked: 1613 times
Been thanked: 4078 times
If it’s under an hour job I would re use those parts.
Rocking it in the 518...
