Long Term Fuel Trim at 10% What is typical for a 1999 S70-GLT
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
After fixing the P0455 code due to a split vacuum line my LTFT went from +20% down to around 10%. I have done a vacuum test with a guage and the 1999 S70-GLT 2.5L turbo engine pulls 20Lbs of vacuum. I would assess that there are no major vacuum leaks. I also cleaned the MAF and also exchanged the MAF with another from the PnP yard.
LTFT & STFT should be close to 0 %. Older engines can run at + or - 5% to 10%. Does anyone know what there LTFT is for this GLT turbo? It only shows 70K miles on the odometer.
Thanks.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
My 98 V70 turbo is at -4.7% and has never really budged off that. I have a 0455 code that I ignore because I don't have to pass emissions. Not sure if they are related
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Do a smoke test to check for leaks. But, i mean 10% yeah i guess maybe high? A few here and there are normal i guess. What kind of mpg do u get?
BMW 540i 2002
S70 Base 2000
800artfreed
I built a home made smoke machine. It did not show any leaks when run through the center vacuum port on the intake manifold. When I introduced the smoke from the intake pipe after the MAF a small amount was visible near the turbo but I could not see the actual location. Mileage varies by driving type. Mileage has been as high as 30mpg on a long constant highway trip. Local stop and go driving is as low as 18mpg. Engine performance is good. Causes of high LTFT are low fuel pressure (I tested it at 55psi), clogged injectors (running lucas injection cleaner now) a bad MAF (I just exchanged it with one from the PnP), a failing O2 sensor that I have not swapped. There is really no difference as of yet.
I am going to run more smoke tests with the turbo shield removed and see if I can find the source of the wisp of smoke I saw before.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
bronco
Post by bronco »
800artfreed wrote: 20 Sep 2019, 18:47 I built a home made smoke machine. It did not show any leaks when run through the center vacuum port on the intake manifold. When I introduced the smoke from the intake pipe after the MAF a small amount was visible near the turbo but I could not see the actual location. Mileage varies by driving type. Mileage has been as high as 30mpg on a long constant highway trip. Local stop and go driving is as low as 18mpg. Engine performance is good. Causes of high LTFT are low fuel pressure (I tested it at 55psi), clogged injectors (running lucas injection cleaner now) a bad MAF (I just exchanged it with one from the PnP), a failing O2 sensor that I have not swapped. There is really no difference as of yet.
I had a ford explorer to fix last month that was at +49% on long term , both banks! :shock: It was a fuel pump issue , kind of a tricky one , initial pressure was ok but it would pump less fuel after it ran a bit. Pressure would erractically drop , it was a volume problem really. In 2003 the explorer had a returnless fuel system with an in tank regulator. I never found out if it was the regulator or the pump but replacing it fixed the issue. It was actually tough to pick up on with a pressure gauge at first but I decided to change the fuel filter and it was off and someone bumped the key and hardly any fuel came out of the line . So I hooked up a clear line and shorted the relay , put the line in a large glass jar and you could see the fuel volume start strong then slow to a trickle. After 10 minutes it did not fill a gallon jar . I was getting codes for all sorts of random things that were extraneous but changing the pump made them all go away.
The high +% fuel trim numbers were the computer trying to correct a lean condition when the called for injector pulses were not providing enough fuel. That year explorer does not have a fuel pressure sensor so there was no code being thrown
Has thanked: 1611 times
Been thanked: 4075 times
Typically out of range codes are thrown at about 20% in my limited experience, so I will guess 10% is in the normal operating range for an older car.
I'll try grab some data from mine
kallekula
Post by kallekula »
30 MPG???? If you get that, stop all work immediately. Dont touch anything and just be happy with your car! πŸ‘
BMW 540i 2002
S70 Base 2000
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
abscate wrote: 21 Sep 2019, 03:50 Typically out of range codes are thrown at about 20% in my limited experience, so I will guess 10% is in the normal operating range for an older car.
Mine is around 20/21% because E85, and doesn't even throw a code :lol:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
800artfreed
......I ran additional smoke test using my home brew machine. Smoke appeared from the intake pipe down near the PTC valve just after the nipple. As it is a PITA to remove and replace. I tried the propane gas trick to see if when the engine ran it would suck in propane and change the fuel trims. There was no difference. I then used the propane to feed propane around the intake manifold and other intake location. No differenc. I will try the smoke test on my other two 1998 S/V 70-T5. They have the same intake piping. BTW I am making the same trip up to Canada this October. Hopefully I won't need the A/C like the last time. I do NOT expect to get 30MPG again. :-(
Some pictures of the test machine. I have a mp4 video but don't see how I can upload it.
interface to the down pipe
smoke machine
smoke machine
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
800artfreed
Here is a link to the Youtube video of my smoke test.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
