Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
Coilovers are in ! The front was a piece of case, basically 4 nuts and 2 bolts. The rear took more time since the shock eye didn't want to fit on the stud, I had to get the dremel and make it slightly larger.
The car now sits 3cm (~1inch) higher, not sure if I like it but I can always lower it.
Also changed the oil, nice color and no sign of water from the E85. I'm sticking to 10W40
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Nice! How do you like the ride?
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Ride is fully adjustable, so can go softer than Volvo OE if you want. I think OE settings equate to 10 clicks on front and 5 clicks on rear on the BCs.
Has thanked: 1611 times
Been thanked: 4074 times
Junior Volvo went to come to see her sister off to grad school inEurope, and Evita the S70 would not crank. I had put a 5 year old battery in which tested Good this summer
She successfully jump packed it , arrived home 2 hours , and we put a new battery in her.
Oil change on the T5 -at 237800
bmdubya1198
I'm betting 5 year old battery is the problem...
I shouldn't talk... I think mine is also 5 years old!
Goupil
Post by Goupil »
Cookeh wrote: 22 Sep 2019, 02:19 Ride is fully adjustable, so can go softer than Volvo OE if you want. I think OE settings equate to 10 clicks on front and 5 clicks on rear on the BCs.
Thanks I'll try those :D I've been fiddling with the adjusters, started with full soft on all 4 corners but it was a lil' bouncy :mrgreen:
I'll report on how I like those once I get a good setup
And I fixed my low washer fluid light :lol:
KHolden
Year and Model: 1998 V70 GLT
Has thanked: 3 times
Post by KHolden »
I'm thinkin this was a good time to have replaced the serpentine...
Nice. Got your money out of that one. Perfectly good spare for a Scot, though.
Cookeh
Post by Cookeh »
Just wondering if a V70 tailgate will be a bolt-on swap, electrics and all, onto my 855? My 855s tailgate has some clearcoat failure, and some rust appearing on the leading edge. I've found a V70 tailgate in the correct colour for significantly less than it would cost me to repair/respray my current tailgate. I did have a search but could only find one post on the matter.
Are the two a straight swap? I know I have to get the bulb failure relay from the V70 too, as the relay for the V70s LED is different to that of the 850s halogen, but beyond that?
Cheers,
Goupil
Post by Goupil »
So things to check on mine:
-how old the battery is
-how's the accessories belt
:mrgreen:
