99' S70 interior light problem, how to troubleshoot?
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Hello everyone,
Most of the time the interior lights in my S70 don't come on when I open the driver door, or the passenger door for that matter.
This, of course, is happening with the overhead switch in the center position. So because of this I leave them turned off so the battery doesn't drain.
However, the other day I tried it out again while sitting in the car and I turned the switch to the center position, and the lights came on :o . I think in this case they shouldn't though because I didn't open any doors.
Does anybody know what could be wrong?
The PO must have wrestled with this before, because the foot well lights were removed when I got the car.
Thanks for any ideas you might have.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Steve's the resident expert on this.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
850 LPT
Post by 850 LPT »
Thanks Evan. The repair will be a snap then.
Has thanked: 1504 times
Been thanked: 3817 times
Trade it in for a Honda
There is a long winded thread about troubleshooting my 1999 S70 with this and its a b****
My car is fine as long as the ignition has not been energized in a while , like hours, but the minute T30 gets 12 Volts my lights latch on and stay on regardless of door position.
BY the way.,, when I went to get keys made and coded to the VIN, I could not get it done as I was told one of the lock modules won't go inactive - a requirement for new keys
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Couldn't it be just the microswitch in one of the door mechanism getting stuck ? And then somehow got unstuck so the lights stays on while the doors are closed
viewtopic.php?f=1&t=75954
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Five page thread on this here
viewtopic.php?f=1&t=88623&hilit=1999+S70NA
you may want to look at the electrical diagram on the first page and run away as fast as you can.
E Showell
Post by E Showell »
Steve -- I changed the driver front door on that car, but I believe you have the old door. To the extent a "lock module" is associated with a particular door, harvesting the module from the old driver's door and swapping over may solve your key programming issue.
'95 855 auto (sold)
850 LPT
Post by 850 LPT »
You have got to be kidding me.....
I just read through Steve's post, and I feel totally defeated already. Since I'm not nearly as smart as Steve I think I am just going to give up.
And buy a Honda.
E Showell wrote: 19 Sep 2019, 14:39 Steve -- I changed the driver front door on that car, but I believe you have the old door. To the extent a "lock module" is associated with a particular door, harvesting the module from the old driver's door and swapping over may solve your key programming issue.
My problem, and I think Dirks , are both logic fail related. I bet he sees the same behavior ido, that electrically cold modules work fine , but something is latching on incorrectly when powered up.
One test for a hyperactive module is if the antenna ring stays illuminated after shut down, that's a telltale.
I think I could get a rocket to the moon with all the parts in this system.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
abscate wrote: 20 Sep 2019, 03:13
Merely the moon? I think you could likely make it to Mars and back...
