Air intake sensor question
Hello all. So I've got a 2004 V70 2.4 non turbo that threw a p0113 code for the air intake sensor. My question is where is this located. Looking this up Ive found that some say it's the MAF located on the intake tube next to the air box. But the new sensor is not the same. Does anyone have a pic of where it is located? Thanks in advance.
- RickHaleParker
- Been thanked: 978 times
Post a picture of the new IAT sensor and the part number.
I found an entry in VIDA that identifies the coolant temperature sensor as the IAT.
Active
Past
Past
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Fcp sells the whole assembly, it's an entire section of the air tube, the MAF and IAT sensors are a piece inserted into this tube, you can either swap the whole tube section, or just remove the MAF/IAT part and swap it with the one in your car. https://www.fcpeuro.com/products/volvo- ... 12#fitment
Before replacing anything, I recommend inspecting the cables near the connector, and cleaning the IAT sensor with a wet q-tip as it often times gets covered with dirt
- 1523 Views
Last post by 454cid
- 1308 Views
Last post by oragex
- 1356 Views
Last post by mar601
- 11 Replies
- 6856 Views
Last post by misha
- 39 Replies
- 8442 Views
Last post by precopster
