The key no longer works on the trunk lock. The spring for the flap door to the lock fell off and is blocking the key from entering.
The alarm module under the passenger wheel well needs a battery so the remote does not work at this time.
Any advise on getting into the trunk from the backseat so I can pull the cord? Thanks.
Unlock Truck From Back Seat? Topic is solved
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
On the S80 the lock actuator is a microswitch and the lock should unlock when using the key in the door. You're saying it doesn't? The key hole in the back is mostly for when there's no power so the switch doesn't work.
- MoVolvos
When the battery died in the Alarm Module in the passenger fender well I lost the use of the trunk remote and button at the trunk. The key hole is also broken as the small flap door spring broke so the face just spins and can't get the key in.Rattnalle wrote: 24 Sep 2019, 11:49 On the S80 the lock actuator is a microswitch and the lock should unlock when using the key in the door. You're saying it doesn't? The key hole in the back is mostly for when there's no power so the switch doesn't work.
Don't have time to remove the Alarm Module Battery so would like get into the trunk from the back seat and tie a twine to the Yellow Emergency Pull Clip and open from the back seat for now. Good thing I didn't go grocery shopping or it would be gross siree by now.
- Rattnalle
Then I'd say your best bet is to send a child through the ski hole in the rear seat to fold the seat down from inside the trunk. Unless you've got very long arms and can reach yourself.
- MoVolvos
How do you get that open from the back seat? The armrest comes down but the plastic does not move.Rattnalle wrote: 24 Sep 2019, 13:25 Then I'd say your best bet is to send a child through the ski hole in the rear seat to fold the seat down from inside the trunk. Unless you've got very long arms and can reach yourself.
- MoVolvos
Had a moment so I managed to pull it down today. I think a credit card inserted at the top of the tab would do it easily. Will update after I open it from the ski hole. Thank you.Rattnalle wrote: 25 Sep 2019, 23:06 I used to be able to pry mine open by hand on my 01. It's a small tab up top then it folds down on top of the arm rest.
- MoVolvos
Used a long thin wooden rod with an eye hook screwed into the tip to pulled the yellowish plastic tab and opened the trunk. Next removed the clips of the trunk lid interior cover and then the 2 screws for the trunk lock.MoVolvos wrote: 30 Sep 2019, 20:37Had a moment so I managed to pull it down today. I think a credit card inserted at the top of the tab would do it easily. Will update after I open it from the ski hole. Thank you.Rattnalle wrote: 25 Sep 2019, 23:06 I used to be able to pry mine open by hand on my 01. It's a small tab up top then it folds down on top of the arm rest.
As I suspected the spring for the flip cover where you insert the key popped off. Son saw it come off earlier and kept it. The flip cover had dropped into the key hole and jammed into the lock. Remove it and now it works. Didn't bother trying to put the spring or the flip cover back just in case it jams again. Will see if debris gets in with the next big rain.
Thanks Rattnalle!
- 1295 Views
Last post by DavidE7
- 682 Views
Last post by micah
- 2070 Views
Last post by 850forum
- 10 Replies
- 3045 Views
Last post by difflock54
- 892 Views
Last post by obdshawn
