Hello and thanks in advance for your help.
I've been working on my son's 1994 850 Turbo. His door was squeaking bad related to a crack in the A pillar, which I fixed with self threading screws... worked like a champ.
When I went to start the car to put it on jack stands for the oil change, it cranks but no start. Battery is good. I replaced the camshaft sensor last spring (less then 6 months)
I'm getting spark from both the ignition coil and the last spark plug passenger side. I didn't test any of the others. When I pulled a couple plugs they looked ok...a little black deposit.
I can hear the fuel pump running when I turn the key and am getting fuel to the rail.
I checked the rpm sensor and resistance is around 300, which I think is good.
I removed the MAF. It looks clean, but still wouldnt start with it unplugged.
I cleared all the codes and tried the ignition again before reading them again.
On the A1 jumper I am getting...
134 Faulty load signal from ignition control module
114 Program selector open circuit or short circuit to supply
I dont know what 114 is referring to?
Is the ignition control module the same as the coil? Would I get speak but no start if it was bad?
What am I missing?
Thank you
Steve
1994 850 No start [solved, lawnmower syndrome] Topic is solved
Badweed
- Year and Model: 1994 Volvo 850 Turbo
So it turned out to be "lawnmower syndrome." I pulled the plugs and put a wee bit of oil in each....jumped the battery (dead from multiple attempts) and vroom!!! Ran like crap for about 10 mins and now back to normal. Great forum.
- Has thanked: 311 times
- Been thanked: 817 times
Thumbs up, well done!
- 9 Replies
- 2441 Views
Last post by jimmy57
- 2957 Views
Last post by Sommerfeldt
- 1263 Views
Last post by FL850_1997
- 1760 Views
Last post by dudeitssm
- 9 Replies
- 2246 Views
