kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I reconnected and resealed my mysterious nokia/bmw bandpass box or whatever it is that i have. Patched up some holes i accidentally did when i Dremeled the crap out of it to make the 6.5s fit. Used jb weld plastic putty. Silicone and window sill foam tape has now made it airtight. I have really no clue what its gonna sound like. One internal 3" port leads air out to two 3" ports in the rear shelf. I parallel coupled the speakers so input imp is now 2ohm. At that imp my amp gives 150w. Like i said, no idea what the heck this will sound like.
BMW 540i 2002
S70 Base 2000
2oldv70
Year and Model: 99 v70 2.4 n.a
Post by 2oldv70 »
Replaced pwr steering pump and serpentine belt.first timer.thou i must have uncovered other issues.oops.99 v70 wont die (completely)
jmcguire
Year and Model: 1996 850 Sedan
Has thanked: 19 times
Been thanked: 9 times
Post by jmcguire »
Pick a part yard near me finally got an 850 in so I went pickin’ over the weekend!
Got a nice set of gray carpet and parts to fix the cruise control (module and vacuum pump). While I had the seats out of my ‘96 850 GLT to replace the carpet I redid the headliner too. Gray carpet actually looks really good even though the original was beige. Ties in nice with the black in the dash. Cruise now works when I lift up on the brake pedal. Had nothing before. Tried adjusting the brake switch but still have the same issue. Going to head back this weekend and pull that switch also.
Put a lot of work into this car over the last year and a half I’ve owned it but it has been one of the easiest cars I’ve ever worked on. Been a joy to bring her back to life after being neglected for years before I got her. Luckily she was low miles at around 55,000. Now she has 63,000 and climbing.
Added photos
1996 850 Sedan
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 28 times
Been thanked: 3 times
Post by Peevarino »
jmcguire wrote: 30 Sep 2019, 17:21 Pick a part yard near me finally got an 850 in so I went pickin’ over the weekend!
Lucky!
Been waiting for months for a local junkyard to get anything useful
09 XC70 3.2
97 855R
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
kallekula wrote: 29 Sep 2019, 22:59 Like i said, no idea what the heck this will sound like.
How is it?
Also -> Amazon link
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Wow, sounds like you found a gem there with that low mileage. Hopefully the timing belt was replaced for age.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
kallekula
Post by kallekula »
matthew1 wrote: 30 Sep 2019, 20:09
No idea yet. Its going really slow this stereo build. Yesterday i modified a tweeter bracket... it takes time...
How is it?
BMW 540i 2002
S70 Base 2000
Has thanked: 1611 times
Been thanked: 4075 times
850 LPT wrote: 01 Oct 2019, 05:45 Been a joy to bring her back to life after being neglected for years before I got her. Luckily she was low miles at around 55,000. Now she has 63,000 and climbing.
[/quote]
We live on the edge of the "oldest timing belt running" club
jmcguire
Post by jmcguire »
Timing belt was one of the first projects completed when I brought her home.
She spent about 3 months on jack stands in the garage while I made her road worthy. Front axles, control arms, end links had to be replaced. Along with all rotors, calipers and pads the whole way around. PnP switch, heater core, blower motor resistor, thermostat, oil cap, upper torque mount, and front seat belts. Then before she came off the jacks I did a full tune up. Plugs, wires, distributor cap/rotor, timing belt, tensioner, water pump and serpentine belt. Also found a nice set of gently used tires.
Since then, I’ve slowly been fixing the odds and ends trying to have everything functioning again. Headlight wipers, air conditioning, interior bulbs and switches, swapped the base stereo cassette for the SC-816 in black with the amplifier, replaced door handle cubbies, added the trip computer, glued down the wrinkles in the door panels, found one of those clear plastic windshield clips to replace the broken one and now the carpet and headliner. I’m sure I’m forgetting a few things...
Anyway, currently working on the cruise control and next will be adding the keyless entry. So basically I probably have more money in this car than she’s worth being a GLT but with my daughter driving now I wanted something reliable, durable and safe. Many thanks to this forum and Robert’s YouTube videos for guiding me through a lot of the repairs above!
* edited for adding repairs I missed when first posting. Cruise control is now fully functioning! It was the cruise cut off switch right above the brake switch that needed adjusted. Didn’t see it when I first wedge myself under the dash.
1996 850 Sedan
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
I was the first person in over 20 years to get the trip computer activated at the dealership.
They charged 1/2 hr and ‘tester’ fee - total was probably 10% of cars entire value.
But a fabulous thing to fool with when highway driving... 35.6mpg over 300 mile test drive
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
