Problems after fuel filter replacement
jimmy57
- Been thanked: 320 times
Re: Problems after fuel filter replacement
I have had several cars that the Owners really didn't want to spend the money and I would tell them to do three key cycles and drive on only to have the car return to normal after a time. If something was in pump outlet check valve or on FPR seat it can wash away and it once again seals.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Why three? Is that a magic number or should it be read as a few turns?jimmy57 wrote: ↑25 Sep 2019, 16:54 I have had several cars that the Owners really didn't want to spend the money and I would tell them to do three key cycles and drive on only to have the car return to normal after a time. If something was in pump outlet check valve or on FPR seat it can wash away and it once again seals.
BMW 540i 2002
S70 Base 2000
jimmy57
The fuel pump runs 2 sec or little less on each key on. 3 cycles is enough to create full normal fuel pressure if there is compressable air in lines and maybe get fuel close to fuel rail where it will start with much less cranking.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
4th morning in a row it started instantly.
Well....it seems that problem is gone by itself.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Started instantly after sitting for last 2 days.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1505 times
- Been thanked: 3818 times
Wait until the Siberian winter hits
- Year and Model: Lots
- Been thanked: 128 times
I tore apart the original Bosch filter in our 1995 850 by cutting it and it had much more pleating and was far better made than a replacement Bosch filter built in 1990 on a 1999 V70 that I also cut up.
After getting holes in 2 USA made Bosch oil filters (catridge type) in succession I am convinced that some Bosch products made these days are not as good as others.
- kallekula
Counterfeit product maybe? I saw this documentary about piracy and it was actually scary. They are even making counterfeit medicine/drugs now!precopster wrote: ↑12 Oct 2019, 22:29 I tore apart the original Bosch filter in our 1995 850 by cutting it and it had much more pleating and was far better made than a replacement Bosch filter built in 1990 on a 1999 V70 that I also cut up.
BMW 540i 2002
S70 Base 2000
- 806 Views
Last post by alschnertz
- 20 Replies
- 11667 Views
Last post by oragex
