98 S70 N/A 5-Speed: Complete A/C job (yay!) not holding a vacuum... (sigh!) How do I troubleshoot this?
- June
- Has thanked: 523 times
- Been thanked: 261 times
Re: 98 S70 N/A 5-Speed: Complete A/C job (yay!) not holding a vacuum... (sigh!) How do I troubleshoot this?
Add freon to the system and use a leak detector device to find the leak. Someone chime in. Possibly you can rent a leak detector? You did coat the O-rings with AC oil before reinstalling and if the compressor was replaced oil in the compressor to coat the front seal? Mike told me those are common misses to cause leaks under vacuum. He also said use Ester oil for O-rings otherwise joints will be hard to pull apart in the future. Thought I would pass his advice on to you. Hope it helps. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 36 times
I think it's the drier. I couldn't really crank it down like l would've wanted to. Will disconnect it, drop it and wrench it.
I might get to it in two/three weeks...
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 1507 times
- Been thanked: 3827 times
I know you got this done Marco...how did you find it and where was the leak?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
I know after doing the Evap coil on mine I developed a small leak on the high pressure side sensor. It was an o-ring that needed to be replaced.
- theWIFES_S70
I actually never got to it. Life got in the way...
Still no A/C on "the husband's S70" now. (The wife is driving an S40 now...)
Retired:
Well bring it up, pick up Dirk, and let’s have a massive “ do three evap party” in Albany before the weather hits. I’ve got dash out time down to 35 minutes
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 332 times
- Been thanked: 243 times
That would be nice, but I have no time right now. We are getting ready for a camping trip in the white mountains over the holiday weekend, and after that I need to split a rather large amount of firewood
But I am reading through these threads in preparation of doing 2 cars. I am pretty sure I need to replace every single AC component on the S70, because things like fittings look very rusty.
The 850 was still doing good over the summer, but it seems that now the leak has gotten bigger and it finally crapped out. But this car has low miles, so maybe just replacing the evap. might do the trick?
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Evap is the only big one, cheap part but lots of labour to get to it. Worse if/when you have to repair the dash mounts.
Once you do the Evap, everything else is bolt on/ off and you don’t lose the car use during the work, unless it’s the compressor (needed for SERP belt)
- theWIFES_S70
Well, abscate, you're forgetting the silly hand contortion you have to accomplish to attach lines to the compressor...abscate wrote: ↑08 Oct 2019, 11:34 Evap is the only big one, cheap part but lots of labour to get to it. Worse if/when you have to repair the dash mounts.
I really should get up there and do this A/C job already. (I really think I need to pony up for a new compressor...)
Retired:
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Best to do that A/C work before winter as you may need functioning A/C to clear the windows in damp cold weather.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
