Are you refering to dark green? This is said to be the last run of T5Rs. They had 500 of them made. They are a quite common in Europe. Maybe you didn't receive alot of them, but here, they are not that rare. I've seen way more green T5Rs in my life than unicorns...
P80 delta link time 3516122
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Re: delta link time
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- Has thanked: 1506 times
- Been thanked: 3818 times
I’ll confess 30 vs 200 is on the edge for me on this one. I think you can get FEBI rather than the brands you now are crappy at the low price, and 5 hours of my time is worth about $100 in my price book.
Last thing to consider. Are your driven roads good shape, smooth , highways? Yes would give a nod to trying aftermarket. I’m at 110k on my OEM and they are still tight.
viewtopic.php?f=1&t=65148&hilit=3516122
Good write up on diy 3516122 by XHeart here
Epic thread from 2006 here
viewtopic.php?f=1&t=9402
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
A quick tip for making the old Delta Link bushings easier to remove.
I just did all of the DL bushings in the wife's 855 a coupe months back.
Run a drill bit along the top of the old bushing to break apart the (plastic) sleeve. (It was 5/16-ish, I think). Then it comes out with minimal fuss. Even having the removal/installer tool they tend to fight on removal.
I used dish soap as my lubricant (much better than any of the greases I've used), and tapped a bit on each side of the bushing, as I would tighten up the installer a bit, to help it drive in true, as even with the installer tool, it would shift a bit and bind.
Those earlier threads have 5-6 year reports on the PPS and Febi cheap delta links. Sorry to be an OEM parts nazi above, they are worth looking at. Maybe buy both and look at them side by side for rubber quality?
You can’t rely on a brand 5 years ago being th4 same , except for Volvo is always a safe bet.
vovo850
- Year and Model: 1995 850 glt
- Has thanked: 49 times
I wish the roads were nice here, but mostly not.abscate wrote: ↑06 Oct 2019, 23:59 I’ll confess 30 vs 200 is on the edge for me on this one. I think you can get FEBI rather than the brands you now are crappy at the low price, and 5 hours of my time is worth about $100 in my price book.
I know it is on the edge, the febi's are the 33 but it's aftermarket chinese quality. Does that mean it's bad? I don't know.
I agree on the OEM too. But just trying to get a gauge on the aftermarket quality.
1995 Volvo 850 GLT N/A automatic wagon
Ping xHeart and the guys up thread to look at their cheap ones 5 years later. I think that is the best you can do.vovo850 wrote: ↑07 Oct 2019, 10:18I wish the roads were nice here, but mostly not.abscate wrote: ↑06 Oct 2019, 23:59 I’ll confess 30 vs 200 is on the edge for me on this one. I think you can get FEBI rather than the brands you now are crappy at the low price, and 5 hours of my time is worth about $100 in my price book.
The price on the OEM ones has soared from about $100 to $200 by the way.
- Has thanked: 292 times
- Been thanked: 765 times
It's a hassle but not that bad to do and due to the way it fails, this is not a mission critical part. Most P80 cars are running on bad delta links, just like they were 5 years ago when there were many more on the road. I will try to post up a pic of mine.
I agree this one is not an easy call, good point to consider how you drive etc., and I tend to be an OEM Nazi too but based on my experience so far I would go with the cheapies again for this car.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
