I'm keeping an eye on the rear suspension. The busing has started to separate from the shock.
The code on manufacturer's plate is C1. Would Sachs for shocks and Lesjofors HD coils be a good replacement for these Volvo originals?
2001 V70XC - Rear shock bushing separating Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Those bushings aren't mission critical for for andling. If you can get something in there to make the connection and the rear end is still damping well (bounces stop quickly) no reason to replace.
Just don't be this guy (2:00 in is best)
xHeart
The spring appears fine, and damping well responsive and firm.vtl wrote: 02 Oct 2019, 18:52 Is it a snapped spring on the photo?
With HD springs and 14 mm stabilizer bar the car will have too much body roll.
For spring there is also Suplex, $30 more. Lesjofors is available in without HD.
Tonyx
- Year and Model: 2001 XC70
- Has thanked: 3 times
- Been thanked: 8 times
Some observation; there are plastic shields, two per side, that protects the shock lower and springs from splash. I don't know if you took them off prior to the photo. They seem to help keeping things off of rather fragile springs in our XC70's.
2003 XC70 230K and counting..,
xHeart
I recall something like that. Are these in the diagram – items 32, 36 and 54?Tonyx wrote: 09 Oct 2019, 10:53 Some observation; there are plastic shields, two per side, that protects the shock lower and springs from splash. I don't know if you took them off prior to the photo. They seem to help keeping things off of rather fragile springs in our XC70's.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
29
They are not bolt-on on 05+ and will eventually fall off on -04 on a long gravel trip, but they definitely protect rear lower arms and lower part of shocks/Nivomats.
I had them installed for couple of Trans-Taiga seasons, lost them in last trip, got a replacement, but never bothered installing them. They need custom locking/attachment scheme, but still totally worth the price.
54 (MY05-) or 32 (-04) you also need, they divert a lot of dirt from the rims.
Tonyx
vtl answered your question so I'll just add that replacing shock/springs on mine was much easier as result of those shields keeping joints and fasteners clean.
xHeart
Undecided on spring, if Lesjofors HD is out then Suplex or $100 more for a Volvo pair.
xHeart
I'm preparing to service rear suspension. What is your assessment of LESJOFORS https://www.fcpeuro.com/products/volvo- ... 70-4295842?
- 1604 Views
Last post by jimmy57
- 3654 Views
Last post by precopster
- 9 Replies
- 1881 Views
Last post by prwood
- 511 Views
Last post by Clemens
- 1768 Views
Last post by MoVolvos
