1996 850 Wagon Service Light On Topic is solved
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Re: 1996 850 Wagon Service Light On
Post by PeteB »
Obviously an amp-clamp is the way to measure the wires individually, wonder if the
parts stores have them to loan.
PeteB
Post by PeteB »
I probably should have started a new thread about the battery dying overnight.
After sleeping on it, I'm guessing that an always hot wire is pinched before the
fuse since pulling fuses didn't cure the high draw. Perhaps it has something to
do with the smashed door - we should replace it ASAP.
Has thanked: 1504 times
Been thanked: 3817 times
Quick check, undo door harness and see if draw drops
PeteB
Post by PeteB »
It would be great to have a wiring diagram that highlights all the always on wiring for just
this sort of problem.
PeteB
Post by PeteB »
OK, got an amp clamp on sale from Sears and checked it out today.
The large bundle of smaller wires at the positive batter post does have one yellow
wire, I previously thought they were all red. The yellow wire has the high draw.
Anyone know what this wire is?
I might just snip it and see what is not working in the car, then solder it back.
I went through all the pages in the wiring diagrams that I could find and did not
find any yellow wire coming off the battery positive. I think that the diagram was
from 1995, not sure.
I had one more thought to pull the engine ECU or any module that plugs in before I
cut the wire.
PeteB
Post by PeteB »
I googled "yellow wire at battery post Volvo 850" and found this thread with another
person having the same problem. They snipped the wire and the car works fine, LOL!
But I'm sure that something is not going to work:
https://volvoforums.com/forum/volvo-850 ... nal-84878/
This is their picture but here is the yellow wire:
That’s aftermarket stuff. Wiring diagrams aren’t going to help there
PeteB
Post by PeteB »
I don't think so, all those reds and the yellow normally go into a big lug that certainly
looks to be factory. In that picture the guy cut out the big factory lug in order to find
the leakage current, then put new lugs on the wires.
That car and our car both have the yellow wire that goes into the factory harness so
I'm quite sure that it is factory.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Assuming you have time, you could follow it and solve the mystery!
PeteB
Post by PeteB »
I'm able to follow it about one foot then it enters a large harness.
