Symptom - car drained an old battery on a two week sit at college. I will get a new battery and test.
My Fluke $6000 VOM was on the fritz for some reason - I wasn't getting a reliable amperage reading, so I broke out the old Micronta
First, I played dead on road with no VOM and tried to troubleshoot with no instruments. I was a getting a thin blue spark on touching the negative to the battery post, indicative of 100s mA leakage - too much. I want to be under 50 mA (0.050 Amp)
First step - removed feed wire from positive battery post - no spark at negative - that means the alternator and diodes seem to be ok.
I went through the entire 11C fusebox (under the flip lid) trying to judge small spark (ok) from big spark but was unable to tell which circuit was pulling current.
I moved back to the big Butt Fuses feeding the Bus and found pulling number 6 cured all ills.
This feeds 5 buss circuits on the 11C, and I found #7 I could then tell big from small current drain. Said circuit feeds radio and a few other things. Pulling #7 makes drain current go from 200 mA to under 5mA
Current math - 200 mA draw will pull about 5 Amp hours per day from battery, or half battery charge in warm weather in one week.
When Abby comes home for long break, I will have a look at wiring and try to sort out - until then she will pull #6 when she parks.
Pictures to come.
1999 S70NA Evita Current drain evaluation and fault testing
- Been thanked: 4068 times
- RickHaleParker
- Been thanked: 979 times
Semi-melted fuse or intermittent open fuse ...?abscate wrote: 14 Oct 2019, 10:41 My Fluke $6000 VOM was on the fritz for some reason - I wasn't getting a reliable amperage reading,
Active
Past
Past
RickHaleParker wrote: 15 Oct 2019, 03:43Semi-melted fuse or intermittent open fuse ...?abscate wrote: 14 Oct 2019, 10:41 My Fluke $6000 VOM was on the fritz for some reason - I wasn't getting a reliable amperage reading,
I think it’s more serious. I’m getting about 200 mA reading with the leads grounded. Bad battery perhaps, but it’s under warranty at least.
On a bright note, Juniorette had a good head for electrical troubleshooting and was able to figure out how to track down a current leak and what order to pull fuses.
- RickHaleParker
You sure it is 200 mA not 200uA or 200 pA? A little internal leakage is expected but not 200 mA.abscate wrote: 15 Oct 2019, 04:41 I think it’s more serious. I’m getting about 200 mA reading with the leads grounded. Bad battery perhaps, but it’s under warranty at least.
Active
Past
Past
I gotta hand it to my almost 40 year old Radio Shack Micronta VOM, workingout of box, and the analog meter was great for catching the dynamics of the current drain.
Each time you connect the battery, a couple of controllers reboot so current jumps, then drops and stabilizes. Much easier to diagnose on an analog meter.
You also never need a battery on an analog current meter
Oh... and by the way, this circuit also powers the d****** dome light and lock controller module that has been poking us in the eye for a year.
Hmmmmmm
Hmmmmmm
And this was found to be a faulty passenger door switch lock button stuck closed.
Once resolved, drain current measures at 45 mA. Probably still some stuff active at that point
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Unplug your radio. Bet at least half of it is the memory refresh power. Betting other half is ECU/ECM memory refresh.abscate wrote: 21 Mar 2020, 06:27 And this was found to be a faulty passenger door switch lock button stuck closed.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I am glad you figured this out.abscate wrote: 21 Mar 2020, 06:27 And this was found to be a faulty passenger door switch lock button stuck closed.
Since I have the exact same symptoms with my S70 I am hoping that the cause is the same.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Well, it solved it for 5 days , then came back
- 63 Replies
- 16233 Views
Last post by JCT5
- 1705 Views
- 3841 Views
- 28 Replies
- 4877 Views
- 590 Views
Last post by wizechatmgr
