Are there any codes stored?
Is check engine light ON?
Do you hear the fuel pump running when problems begins?
1998 V70 T5; problem hot starting & occasional brief power loss at speed
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
I have no codes or check engine light . Its a 2000 T5 .
- misha
I would check is there a noise from fuel pump when car will not start.
Could be a fuel pump failure caused by overheating it's internal parts.
Topic says 1998 V70 T5???
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
clifford06
Sorry for the confusion. OP has a 98 . Mine is a 2000 t5 ( the bastard years of s70 ) . I was having problems like OP , and joined in the thread seeking help .
After replacing the main relay back to original , it won't start at all . Engine turns over but no start. Shot it with starter fluid and still no start . No check check engine light or codes . I think its decision time . Send to shop for a diagnosis or relieve myself of this stress and sell it for the price of a new set of tires for my truck .
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
See if you can find someone with VIDA to verify it isn't an immobilizer issue.clifford06 wrote: 14 Oct 2019, 17:46 Sorry for the confusion. OP has a 98 . Mine is a 2000 t5 ( the bastard years of s70 ) . I was having problems like OP , and joined in the thread seeking help .
- Been thanked: 4068 times
So you have both fuel delivery and ignition problems,that’s a tough one.clifford06 wrote: 14 Oct 2019, 17:46 Sorry for the confusion. OP has a 98 . Mine is a 2000 t5 ( the bastard years of s70 ) . I was having problems like OP , and joined in the thread seeking help .
Get VIDA up and running
clifford06
Thanks for the replies . Sending it to local Euro shop for VIDA scan at a cost of $ 120 . If the repair is a DIY , I'll keep it . Depending what the problem and cost to fix . If not , it will be taken behind the barn and put down , " Old Yellow " style . ,
With my luck it will be something dealing with ECM , or something to costly to fix . If diagnosis is bad I'll post on here to help fellow members .
clifford06
Greetings. Haven't had a chance to send car to shop . I went out today to get some papers out of it , and tried to start it. I be damned ! It started on the first try in over 2 weeks. !
