MVS-Amazon link helps MVS!
2000 V70 NA needs a radiator
Herb Goltz
Year and Model: 2004 & 2006 XC-70
Post by Herb Goltz »
I noticed some coolant dripping from the right corner of the splash guard this morning-- it looks like it is time to replace the radiator. I am planning on either a Nissens or a Spectra Premium radiator and new upper and lower hoses. It looks like I will also need two of the green retainer clips for the transmission cooler lines too, along with o-rings.
How do you remove these retainer clips? The fittings on the radiator are rusted to oblivion-- I am surprised that they aren't leaking...
Any other tips would be appreciated!
Goupil
Year and Model: 98' V70 LPT
Has thanked: 7 times
Been thanked: 14 times
Re: 2000 V70 NA needs a radiator
Post by Goupil »
I removed the retainer clip using C clip pliers, it works great.
My V70 needs a radiator as well, planning on getting a Nissen but I'm not sure about aftermarket hoses (anyone knows if Gates hose are any good ? )
1998 Volvo V70 B5254T M56
1993 Volvo 940 D24TIC M46
850 LPT
Year and Model: 96' 850
Has thanked: 66 times
Been thanked: 45 times
Post by 850 LPT »
Radiators are super easy on these cars. Do yourself a favor and slide out the fan/ shroud assembly as a whole. This has worked well for me.
I use a large screwdriver to spread the clips apart, then you can slide them off.
Good luck.
96' 850 sedan, base, auto, pewter/charcoal, 117k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 216k miles
05' V70, 5-speed manual, loaded, mistral green/ tan, 150k miles
79' Ford Capri S, Euro Spec 2.8 V6, T9 5-speed manual
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Herb Goltz
The clips on the transmission cooler lines I am referring to are the green plastic ones from '99 onward. Do you need a release tool like the Ford quick release fittings on the AC?
Clemens
Has thanked: 108 times
Been thanked: 59 times
Post by Clemens »
Nissens is good. I have three of them.
Be sure to spray the large bolts that hold the radiator in place thoroughly with penetrating oil before and while doing the job. The thread into round nuts (good choice, Volvo) that are tack welded to the radiator support. I have broken off these nuts on occasion, and there are things more fun in life than grinding the bolts off afterwards.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 29 times
Been thanked: 54 times
Post by xHeart »
Herb Goltz wrote: Thu Oct 17, 2019 1:19 pm The clips on the transmission cooler lines I am referring to are the green plastic ones from '99 onward. Do you need a release tool like the Ford quick release fittings on the AC?
These are even simpler.
Press the tabs on green clip inward (thumb and index finger) and pull the connection outward. It is the connection that needs your strength to pull off, NOT the squeeze on tabs.
Use new set of Volvo o'ring when installing. Check part number.
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
