Headlight Assembly Replacement?
rivera0608
Year and Model: 2010 XC70
Has thanked: 3 times
Post by rivera0608 »
My headlights are catastrophically dim. I basically depend on the street lights to see well at night, if there are street lights. A few months back I bought new bulbs, and no improvement. The interior reflectors are pretty brown/faded, so I'm guessing that's the main reason I'm not getting enough brightness.
However, before I go and buy new headlight assemblies, is there a way to troubleshoot if it's a possible wiring issue? Maybe I'm just not getting enough voltage to the bulbs.
Any tips are much appreciated!
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Measure the voltage drop across the bulbs and compare it to the voltage drop across the battery.
Active
Past
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If the reflectors aren’t mirror shiny any more, start researching.
There are plenty of great posts here about 70 series headlights.
The “jewel” versions from later P80 C70’s get rave reviews
and will bolt right up. Check out OEM and Depo options.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
FCP sells a TYC brand of headlight replacements that are relatively cheap and pretty decent quality. More or less exact copy of the OEMs. There aren't too many great ways to refurbish dead reflectors, and most junkyard ones will probably be crappy too at this point.
You could also buy clear lenses and do a projector retrofit for amazing results, though at an increased cost.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
I had a similar issue in my v70. Spent a $100 on a projector kit and any old HID set and it was more than adequate. Aim the projectors properly and you will not blind any oncoming drivers. One word of mention is that they might not pass safety depending on where you are. The most important thing with the retrofit is to ensure your lights are aimed properly!
2008 S60 2.5T Auto (Sold)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I went with jewels in my V70R and love them. Light output is WAY better than the stock headlights... my reflectors were horribly faded and I could barely see a foot in front of me. I highly recommend them, even if you stick with the stock H11 or H7 halogen bulbs.
Also, check to see if you have the pig tails in place on the headlight harnesses. Remove that and you'll get slightly brighter headlights. It's like an extension harness between the headlight connector on the light and the connector from the body harness.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
ecbsykes wrote: 17 Oct 2019, 17:33 FCP sells a TYC brand of headlight replacements that are relatively cheap and pretty decent quality. More or less exact copy of the OEMs. There aren't too many great ways to refurbish dead reflectors, and most junkyard ones will probably be crappy too at this point.
I installed TYC headlight assemblies in my two P80s (98 and 99), and the difference was dramatically better. Plenty of light now. I posted before and after photos here a few months ago.
All U.S. market models.
All running and on the road.
Has thanked: 311 times
Been thanked: 817 times
Eddystone's before-after post about TYC headlights: viewtopic.php?f=1&t=88189
zeke1256
Year and Model: S70 2000, 1995 850,,
Been thanked: 6 times
Post by zeke1256 »
I have a 2000 S-70, headlights were very dim, tried different higher output bulbs, very little difference. I believe the inner reflectors were basically shot. Bought aftermarket TYC headlight assemblies, HUGE difference, like driving a different new car. However, one headlight wouldn't adjust up or down, my bodyman said the inner adjustment wheel must be broke or something. Ordered new one, returned old one for refund. New one was able to adjust so I'm good again., each light assembly around $90.00, can't go wrong with these.
Andrew Vanis
Year and Model: 1999
Been thanked: 11 times
Post by Andrew Vanis »
Just ordered some TYC on RockAuto for $65 each (remember your 5% RA discount code)
1998 V70 NA (11/97 build date) 230,000mi
