Air Intake Hose Hard To Push On The Throttle
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I find it is much easier to tighten or loosen the many hose clamps that are out of sight by using 1/4 inch drive ratchet and sockets on the hose clamp head. The socket stays on the head unlike a screwdriver. Sockets do not need as much push while turning. Using assorted extensions make the ratchet handle in a easy to operate position. And, the ratchet allows getting the clamp suitably tight to avoid blowing off under boost.
It seems everything I do on the T5 starts with removing the air intake tubes.
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
My only next issue is the 750 rpm iddle rev. Just called XeMODex and was told that speed is normal for my 2001 XC.
Oka
Post by Oka »
Ooopsy! Guess I spoke too soon.
This morning neither the remote starter nor the key would start the car.
Here are some faults and an audio of the starting sound.
https://drive.google.com/open?id=1Gqvzo ... DuGjaSfOJi
Just curious, both the OEM security system and the Viper Remote Starter security systems all are functional at the moment.
I have been enjoying the nice and very responsive ride since replacing the throttle device, need to get back to it as soon as possible.
Thanks in advance.
Oka
Post by Oka »
Hello folks. Any ideas on where to go from here?
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Oka
Post by Oka »
https://drive.google.com/file/d/1Gqvzor ... sp=sharing
Thanks in advance.
Oka
Post by Oka »
Hello folks, am waiting for any ideas on where to go from here?
Thanks.
Oka
Post by Oka »
While waiting to get the Ambient and Coolant Temperature sensors to arrive, I just tried to start the car and on the dash, it shows:
IMMOBILIZER
SEE MANUAL
Oka
Post by Oka »
https://www.youtube.com/watch?v=mke5DcMbM6c
For our 2001 XC, would the design of the Cam and Crank Sensor wiring interfer with the ECM?
Bye the way, the main part of the message is between 00:45 - 01:45.
Thanks
