Kudos to spouse for being aware of changes in the operation. The alternative is the kind who don’t notice the little genie oil can light is lit up on the freeway and drive on, for a short distance.
How many miles are on this beast?
I solved an intermittent rough idle finding one split vacuum hose in the purge circuit. If those are still original, spending an hour to replace everything makes sense
Coils and plugs should all come out, if they have 150k or more on the coils, I would put 5 new ones in. Sell the other 5 for $50 with an asterisk that one is bad. I just had a coil on the 1999 that failed at cold start then cleared up, then would fail ten minutes later
Perplexing Misfire. Only when started warm
- Has thanked: 1611 times
- Been thanked: 4072 times
- 2154 Views
Last post by optowalt
- 3559 Views
Last post by 93ForMe
- 828 Views
Last post by oragex
- 1385 Views
Last post by cuhfs
- 1935 Views
Last post by jakeempero
