93 850 Recirc damper motor calibration?
850man
Year and Model: 1993 850 GLT
Post by 850man »
I am installing a good used replacement recirc air damper motor (Volvo #6849557).
Damper motor - 4 pin
6849557 damper motor.jpg (89.06 KiB) Viewed 1120 times
I connected/ installed motor and observed the actuation rotation (angle) exceeds the damper arm's travel, causing noticeable motor to bog under this stress.
I carefully opened the motor and everything looks great (gears, lubrication, "potentiometer" tracks free of debris, etc.)
**Is there a ECC recirc damper motor calibration required? If so, can someone share with me this procedure so I can reduce the motor rotation? Other suggestions? Thanks!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I haven't done the calibration procedure before, so I can't offer help on that.
But, I have replaced the damper motors before. If you rotate the replacement damper to the same position that the old one was in when you removed it, you may not have to do a recalibration.
