1999-2000 are the "bastards"
2001- is P2
A late calendar year 2000 build will be a P2
XC70 Climate Control Temperature Sensor - Replace or Repair?
Ms242245V70
- Year and Model: 01V70T5
I soldered the thermister wires at the tips and my thermister is now working. Ordered a new one from Mouser anyway. 2001 v70 t5
That is a very high value resistor.
I donβt know if you can use a junkyard CCM but I would certainly try
Actually dug around the forums for a good hour and found out that people replaced/fixed this issue by getting a NTC Thermistor with similar values to fix the issue. Going to give it a shot this week, only 10$...
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
CCM notes and photos, includes thermistor replacement.
https://app.box.com/s/8m779rkh2pdglnxtcv69nsyhmnm8x1dt
Thanks
I already took everything appart though but that guide would have been usefull while doing it. Not that hard of a job but I guess Ill clean out the little fan while Im in there. Got my part on amazon, was 10$ for 100 NTC glass thermistors while a 10k value so technically should also work with plenty of spares...lol
- Been thanked: 504 times
My 2005 XC90 2.5T with 120K miles ...
In the process of cleaning the little vent (where the cabin sensor is located as in the video below), I damage the sensor. So far no issues with heat etc.
What do I need to do?
- Leave it alone?
- Is the sensor that crucial?
- Is the sensor available somewhere?
- Leave it alone?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Broken thermistor will cause things like no rear windshield defrost, no heated seats, fluctuating or incorrect cabin heat - at least in auto mode, perhaps some more. The faster way is a walk to the junkyard, and undoing the black plastic piece that is housing the thermistor. I believe you can also get the sensor aftermarket (try to google the specs, perhaps 10kohm but needs other specs as well) however not sure how accurate or sensitive a cheap chinese one would be, so perhaps need to go with a good brand. The small fan behind the CCM will also be quite clogged. I made another video with more details accessing the thermistor
Thanks,
There is an ebay seller selling the Thermistor for Volvo HVAC panel.
Already bought it.
Will install in my 2005 XC90 this weekend and report back.
PS: The radio for XC90 is one BIG piece, so it is a bit different than S60 HVAC panel, but the idea is the same...
Already bought it.
- 4713 Views
Last post by EChem
- 2302 Views
Last post by packetfire
- 4382 Views
Last post by jimmy57
- 850 Views
- 11 Replies
- 6761 Views
Last post by maxi948
