Hi,
Regarding a '95 T-5R with a B5204T
I've tried searching and found some contradicting answers on the topic of gaskets between the exhaust manifold-turbo and between the turbo-downpipe.
Since I can't find replacement gaskets for my car.. Did Volvo intend to NOT use gaskets?
Exhasut/turbo Gaskets, YES or NO?
850T5Ritalia
- Year and Model: 1995 T-5R
- Has thanked: 5 times
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 277 times
- Been thanked: 85 times
When I did mine:
turbo-downpipe there is none
Manifold-turbo I got a metal gasket. But, I didn't use it as it was impossible to get it on right with the studs and I bent it... so I threw it away. Probably better to use on there, but it was without gasket when I took it apart. Maybe it helps with preventing manifold cracks. You don't need it to get an airtight seal.
850 T5-R '95 auto
850T5Ritalia
Thanks! Ill order one for the manifold to turbo and Will see if i can make it fit properlyhausmeister wrote: 23 Oct 2019, 04:00 When I did mine:
hausmeister
Good luck. I just gave up that day, didn't have the nerves...
850 T5-R '95 auto
- 1255 Views
Last post by Clockboy
- 250 Views
- 996 Views
Last post by 93Regina
- 882 Views
Last post by hermechanic
- 876 Views
Last post by stephansvolvo
