WHY - Lost "Dice-206751" Communication Tool
After Login, user chose "Define Vehicle Profile"
But there is no Communication Tool to chose, only a red cross.
OK - Dice Hardware show as ok in Computer Management
OK - Green led is blinking on black hardware box with USB cable
OK - Green icon show up at bottom and then launch "Vida All in one"
Volvo S40 2002
Vida Dice 2013d
I used it for 18 month ago and there was no problem, same car and same computer and same software, the only new installed program is "Autocad" and "BMW scanner"
What can be the problem ?
WHY - Vida Comm Tool Error Topic is solved
- RickHaleParker
- Been thanked: 977 times
Something messed with the Registration. This happens from time to time with a Windows update.
Solution:
Vida DVD:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems,
xxx =x86 is for 32bit operating systems
Reboot and login.
Solution:
Reboot and login.
Active
Past
Past
Now Vida Dice is working after some updates.
Installed IE9 32bit as recommended
Updated reg files after I found out that Laptop had .NET version 4.5 and greater
viewtopic.php?f=40&t=78173
Thanks "RickHaleParker" for your suggestions.
- RickHaleParker
Get the 2014D_RePack. It works with IE11 32 or 64bit and with .NET version 4.5 installed. No VM required. Lots of headaches out the window.laser wrote: 23 Oct 2019, 09:24 Now Vida Dice is working after some updates.
Active
Past
Past
ratlinebrain
- Year and Model: Volvo XC60
It works for me. Thanks!RickHaleParker wrote: 23 Oct 2019, 11:47Get the 2014D_RePack eggy car. It works with IE11 32 or 64bit and with .NET version 4.5 installed. No VM required. Lots of headaches out the window.laser wrote: 23 Oct 2019, 09:24 Now Vida Dice is working after some updates.
GwenSimmons
- Year and Model: XC90 2005
Your VIDA software may not be detecting the DiCE tool due to driver issues or conflicts with recently installed software. Try reinstalling the DiCE drivers and ensure no other programs (like AutoCAD or BMW Scanner) are interfering. Also, check if the DiCE Diagnostic Tool recognizes the device.
schoolboy runaway
schoolboy runaway
In this exciting sandbox game, players must collect resources and craft tools to survive. The game challenges players to think strategically while exploring new areas and facing various threats in different biomes. With new obstacles emerging frequently, Miniblox ensures that no two playthroughs are ever the same. Creativity and adaptability are essential as players shape the world around them and take on challenges that test their skills.
- 2325 Views
Last post by motormikeyman
- 457 Views
Last post by ggleavitt
- 4899 Views
Last post by doublebug
- 11 Replies
- 36033 Views
Last post by menyayto2
- 7023 Views
Last post by Klem
