Rear bumper bracket, Rear Sway bar information
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
If it's in the shop for the sway bar let them do it. IIRC one of those bolts sits right on top of the rear exhaust pipe, and takes a beating from all that heat. Odds are you will break one of the two off, which I of course did. I replaced with two new ones, genuine Volvo, 11-12 bucks a piece, maybe? Car lived in SE USA all it's life as well. Rest of the job is easy, though, fender rivets minor PIA. New brackets, yeah for sure.
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
Well... the mechanic, who owns a Volvo, says there is a weld involved, so its a bodyshop job to take it apart.
Anyone think this is correct for a 1995 850 turbo wagon?
Maybe I'll take that offer of a pair of brackets, and get the rest of the hardware, and try doing it myself if it doesn't keep raining.
But they are getting a junkyard sway bar since they don't make them anymore... seems they have several odd diameters, down to a fraction of a mm... Other pieces & bushing were no problem.
NEVER OPEN THE HOOD !!!
850forum
IDPA is giving slightly different volvo PNs than in this post:
1999 V70T5M56 Rear Bumper Bracket Replacement 6816114 and shock cup 3546435
abscate » June 26th, 2018, 11:21 am
2 each 6816114 Brackets
IDPA says volvo says 6816115
4 each 988182 986504 Flange Screw
IDPA says volvo says M10x20 988182 the short ones
2 each 982831 Bracket screw (the long ones; called flange screw by volvo)
IDPA says volvo says PN 982833 for the long ones
ALSO 6 POP RIVETS FOR THE FENDER ATTACHMENT - any blind rivet.
He says that the flange screws are a hardware store item as long as I can find the good quality ones not the cheap junk usually sold. What am I looking for, is "class A" the term? I know good bolts have one, two, or three lines on the bolt head showing their strength.
- Been thanked: 4068 times
Standby
- Has thanked: 311 times
- Been thanked: 817 times
No.850forum wrote: 24 Oct 2019, 11:21 Well... the mechanic, who owns a Volvo, says there is a weld involved, so its a bodyshop job to take it apart.
Anyone think this is correct for a 1995 850 turbo wagon? ...
My 95 was a sedan, but no welds when I did this repair there. And no welds when I did it on my 96 wagon. And I've never heard of anyone dealing with welds for this repair, back to 93 model cars ...
from viewtopic.php?t=56982&p=288019 the best way to tell what diameter a P80 sway bar is, is by the color of the paint splotches on it:
front sway bar part #s:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
rear sway bar part #s, probable O.Diameter:
9191459 (marked green) 19.5 mm
9191461 (marked yellow) 20 mm
9191462 (marked blue) 20.8 mm
9191494 (marked black) 21 mm
It's nice to get a thicker bar if you can, but the green one in the back is better than none at all back there.
9173982 O.Dia 20 mm (marked red) [font=]available as of March 2020, about $180[/font]
9173983 O.Dia 21 mm (marked yellow) available as of March 2020, about $180
9173471 O.Dia 21.5 mm (marked yellow/blue) [font=]NLA - shows backordered with no date.[/font]
9191459 (marked green) 19.5 mm available as of March 2020, about $150
9191461 (marked yellow) 20 mm NLA as of March 2020 NIVOMAT
9191462 (marked blue) 20.8 mm available as of March 2020, about $150
9191494 (marked black) 21 mm available as of March 2020, about $150
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
Do you still have them? If yes, what it would cost me with shipping it to 60634.kranz wrote: 22 Oct 2019, 16:56 I have a rust free pair complete with hardware. We don't know what rust is here. Yours for cost of postage. That is unless you already made a deal with Abscate.
OOps, I may have spoken too soon. These came off of a V70. Check for compatibility with an 850.
Part number is 6816114
I think I have two decent ones of Clarke, and I have two new bolts, but shipping will kill it.
You can buy brand new with free shipping from FCP for about $50 all in, add brake bleeders if you are a bit short of the thresh hold
- 10221 Views
Last post by SuperHerman
- 10 Replies
- 6411 Views
Last post by volvolugnut
- 12 Replies
- 8767 Views
- 54 Replies
- 16318 Views
Last post by 850oldschool
- 1449 Views
