P80 850 rear bumper bracket bolts (982831, M10x130mm)
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Re: 850 rear bumper bracket bolts
I just used some long M10's I had purchased a long while ago from McMaster for another project.(Have had that bag in the garage for about 8 years now...)
- Has thanked: 1500 times
- Been thanked: 3812 times
Remember if it is SWMBO's car, never comment that "it looks like your back end is hanging a bit low". The potential for misunderstanding is high, the concomitant misery long-lasting, and the ability to recover almost nil.
- Chuck W
I've been using these rivets for my cars. Regular ones work, but the plastic-coated ones are nice.
EBAY LINK
EBAY LINK
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
I understand that it is the NUTs which are welded to the car.
This makes it necessary to get the correct matching bolt diameter & thread.
The size of the head is irrelevent.
I don't know if the welded bolts are accessible enough to use a tap+die to change the thread. If they are deep inside that beam, might not be able to reach them.
NEVER OPEN THE HOOD !!!
- Has thanked: 292 times
- Been thanked: 765 times
Wish I'd seen this a few days ago! Those are very close to original if not the same, and are a good price.
I need to do a bunch of riveting across the P80 fleet this fall, bought these they are half the price even of the eBay ones but not exactly the same style https://www.amazon.com/gp/product/B07H8 ... UTF8&psc=1. Hopefully they will last.
I know the GM rivets work great in this application since I've bought them from other vendors and used them on the P80s. However I don't know yet about the quality of these ones from Rexka, they haven't arrived yet. Hopefully just fine we will see.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Chuck W
I'll be interested to see how those work, also.
I need to replace inner fender liners and a driver rocker cover on the 854, but I should have plenty of the plastic-coated ones on-hand for that.
850forum
Is this a good spec? Ebay 16 for under $12 (page closed after I paid or I'd give the URL)
Turbo Wagon 2.3L L5(4 mm Diamater)(12 mm Flange Diameter)Aluminum w/Black Polyethylene Coating on Flange
Manufacturer Part Number: 979878
Warranty: yes
Brand: MTC
EDIT: here it is:
https://www.ebay.com/itm/264245866679
Set of 16x OE Quality Bumper & Wheel Housing Rivets For Volvo 1993-2011
$11.49
Warranty: yes
Brand: MTC
EDIT: here it is:
$11.49
- Chuck W
Actually no - I looked at those when I was shopping and don't think they will work.
If the picture is accurate they are not split rivets, just standard. You really want split rivets in this application.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
