Headlights dim all the time Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
On my Impala Headlight bulbs seemed to be normal brightness, lighting up the road and in front. On my 01 V70 it was the same case, no issues. Now on this 98 v70, the headlights seem dim. They don't light up the road except maybe 5ft in front of me. the only way to know that is by leaving forward in my seat to look at the road directly over the hood. otherwise it seems as though I have no lights on while driving down a dark road. Interestingly though, the two times I've gotten out to look at my lights head-on, they are pretty bright. They don't seem bright when I'm sitting in front of a building though. Also the brights seem to be marginally better than normal brightness. I'm sorry that it's never a short story with me. But yeah that's how it is. Are all factory v70 light housing units the same like this or is it the bulb?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- RickHaleParker
- Been thanked: 979 times
Take a close look at the condition of the reflector. The silver reflective coating deteriorates over time.
Active
Past
Past
- Has thanked: 311 times
- Been thanked: 817 times
There have been a lot of posts about this recently, browse the topic titles or do a quick search.
Your best solution is to buy new headlights, about $80 a side these TYC are a good option: viewtopic.php?f=1&t=88189
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I've tried coating it on my old 98 S70 and it did not improve it much. Replacement is the only solution.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Check the quality of your reflector, either by carefully removing the lens or by shinning a flashlight into the housing. The reflective material tends to oxidize and flake off with age.
If the reflectors don't look bad, you lights may just not be aimed properly. RobertDIY has a video on how to adjust the P80 headlights, and there are countless videos on youtube about how to aim your headlights properly.
Knows enough to be dangerous
- CIK7
No way I can afford to buy headlights. I'm going to tape some tin foil inside, replace the bulbs, and check how to angle the lights.
- CIK7
SOLUTION FOUND: thank you WhatAmIDoing for the advice. I didn't make it to research part of angling the lights, found how to do it by accident by fiddling with my own light. I did not get before and after pics. Sorry.
1. I locked the angle down
2. I added aluminum foil for reflection
These solved the issue, now I can see.
3. As an extra way to feel that I did something, I rewired the light harness with fresh wiring and connectors.
Now to do the driver side.
- MoVolvos
You mean you adjusted the direction of the light, whether up and down or left and right?
What did you use to hold down the aluminum? It looks like a partial rather than covering the entire reflector?
- CIK7
1. I saw 2 plastic ball joints that pivot and slide within a bracket that extends to the rear of the reflector unit. The reflector unit angles side to side SLIGHTLY. But it angles up and and down about half an inch. Look at a v70 headlight you'll see 2 gears interconnected. THAT controls one of the angle brackets. Then there is a plastic finger that slides into a rubber boot. These all seem to hold and control the light angle. Mine locked into place when I moved them.MoVolvos wrote: 26 Oct 2019, 22:39You mean you adjusted the direction of the light, whether up and down or left and right?
2. I did think about the heat when I used tape on the aluminum foil. Also the passenger side unit is the one I did first. I did a full foil wrap on the low beam socket, only the top and side on the high beam. For the driver side unit, I did a full foil wrap for both sockets. Im sorry I didn't take a pic before I put the glass back on.
- MoVolvos
Thanks, I thought that was what you meant (the adjustments) when you wrote locked down the angles.
I had considered Plumber's Alum Tape for my S70 but this was before LED's were in use. It gets very, very in there with Halogens.
https://www.amazon.com/Aluminum-Tape-Fo ... B01FROBUXE
