What did you put off doing to your P2 Volvo today....... Now Sticky!
hethaerto
Year and Model: 02 Volvo S60 T5
Been thanked: 3 times
Post by hethaerto »
I just put off pulling the blower motor to replace the resistor (blower runs constantly, just pull the fuse).
8)
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
Totally put off getting under the front end and figuring out what that clunk noise is when I take a hard slow RH turn.
I think it is the lower control arm bushings, and I think that it is contributing to the TCS light I get when I take that RH turn.
tyguyc
Post by tyguyc »
Today I put off putting gas in my tank. For no other reason than to see how correct the computer is a indicated 0 miles range left. Filling up today after work.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Put off doing inner and outer tie rods today, it's windier than hell in the lower Hudson Valley and can't run my compressor because we have not had power since 1:00 a.m.
Has thanked: 1609 times
Been thanked: 4064 times
[/quote]
You will need the torch, too.
:lol: :lol: :lol:
Just knocked off E83 front end work, and the wind almost blew over my press!
Stuck torsion arm bushing
:lol: :lol: :lol:
Say Hello to my little Friend.....
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Very windy in Montreal as well, almost seen snowflakes. Was driving inside the city and all of a sudden one of these large recycling bins on wheels run across the street like nobody's business - too bad I didn't had a camera
Those are actually aliens. Once a week they muster the platoon, stand to attention on the street, and then send in scouting reports to HQ, hidden in trash. You can observe a lot by watching.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
abscate wrote: 01 Nov 2019, 12:10Just knocked off E83 front end work, and the wind almost blew over my press!
If they're really stuck, you can drill out the rubber bushing in several places around the ring, then it has little resistance left.
Is there not an outer bushing ring/sleeve inside the arm? If so, once the middle is shoved out, you can then use a loose hacksaw blade to cut through 90% of that sleeve and it's a fairly easy chisel job to pop it out. I've never tried the torch-the-bushing idea - doesn't seem like it's good for the arm (especially if alum!) or your lungs.
20 tons of press makes short work of stuck stuff
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
abscate wrote: 11 Apr 2018, 04:22
Rattnalle wrote: 09 Apr 2018, 11:58
hethaerto wrote: 09 Apr 2018, 11:46 Luckily in TN safety inspections are not required. However, it's easier to buy a well-maintained car in states that do require it.
So do you just drive around until you yourself decide the car isn't worth keeping or are there still rules but you need to be stopped and checked by chance for anyone to find out if you're following them or not?
Neither of the above. Isn’t AMERICA a great place? If you visit here, some States you will be amazed at what you see on the road. In NY we have safety inspections each year but they are about 1/3 as comprehensive as Europe
I got a BMW back from a dealer inspection with 1 mm of rear brake pad left because inspection only requires pulling one front wheel
Freedom and safety can be mutually exclusive. I prefer the former. With it I can see to the latter myself better than the state can.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
