Does anyone have some wisdom for wiper blade replacement? Mine are looking pretty rough, trying to avoid buying the wrong thing. Was considering these?
https://www.amazon.com/Replacement-Wipe ... B013AUNJSG
Windshield wiper recommendation for 2000 S70?
wrybread
- Has thanked: 15 times
- Been thanked: 15 times
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I bought the second cheapest rain-x blades at walmart (beam type about $7.50 a piece). They've been on the car for 20k+ miles and seem to do a good job. You don't have to spend a lot to get a lot.
Knows enough to be dangerous
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
It is imperative that you only use OEM Volvo wipers on these cars. Other wipers will just fail on you, and then you will have to go out and buy Volvo wipers, anyway. It is false economy to use non-OEM Volvo wipers. Do it right the first time. I'm only kidding. It's amazing how much difference there is from brand to brand in wipers and how they have all gotten so expensive.
All U.S. market models.
All running and on the road.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
wrybread wrote: ↑04 Nov 2019, 09:57 Does anyone have some wisdom for wiper blade replacement? Mine are looking pretty rough, trying to avoid buying the wrong thing. Was considering these?
Costco use to sell those for $7.99 each. Currently they are selling Michelins for $8.99. It was on sale for $5.99 a couple of weeks ago. The Good Years had a hard shell on top whereas the Michelin's are soft / rubbery so it contoured with the blade on the windshield. Had lots of trouble with the Good Years and glad Costco got rid of them.
- MoVolvos
I was starting to rethink...Eddystone wrote: ↑04 Nov 2019, 19:50 It is imperative that you only use OEM Volvo wipers on these cars. Other wipers will just fail on you, and then you will have to go out and buy Volvo wipers, anyway. It is false economy to use non-OEM Volvo wipers. Do it right the first time. I'm only kidding. It's amazing how much difference there is from brand to brand in wipers and how they have all gotten so expensive.
- MoVolvos
Not sure if the cover on the Good Year is still hard plastic. Pivot and flex in 2 sections so blade does not contour.
Michelins should work better or else Costco's great return policy just takes them back.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I have been buying the individual rubber inserts and replacing those once or twice a year. The inserts are available delivered from China for about $2/each. You have to rethread the insert through all the clamps -- it takes a little time, patience and double checking but it works well.
I have bought three times from this seller and it has been a good deal so far:
https://www.ebay.com/itm/1Pc-6mm-Pro-Ca ... 2673528865
- Has thanked: 1502 times
- Been thanked: 3817 times
FCP baby. You know why
IPD does this too, now
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
I fully understand why stores stopped carrying these inserts but I sure do miss being able to buy just the inserts. It seems like such a waste throwing out perfectly good frames . Granted, these days, very few people change their own wipers and hardly any of those would go to figuring out to replace just the insert.jreed wrote: ↑05 Nov 2019, 05:21 I have been buying the individual rubber inserts and replacing those once or twice a year. The inserts are available delivered from China for about $2/each. You have to rethread the insert through all the clamps -- it takes a little time, patience and double checking but it works well.
OP. Those wipers you linked to would work but seem to be quite expensive. I seem to change wipers on my car 2x a year and spend about $15 a pair. I generally wait until I find them on sale at Napa/Walmart, etc and get a few pair.
-A
- amblerman
amblerman wrote: ↑05 Nov 2019, 09:19I fully understand why stores stopped carrying these inserts but I sure do miss being able to buy just the inserts. It seems like such a waste throwing out perfectly good frames . Granted, these days, very few people change their own wipers and hardly any of those would go to figuring out to replace just the insert.jreed wrote: ↑05 Nov 2019, 05:21 I have been buying the individual rubber inserts and replacing those once or twice a year. The inserts are available delivered from China for about $2/each. You have to rethread the insert through all the clamps -- it takes a little time, patience and double checking but it works well.
OP. Those wipers you linked to would work but seem to be quite expensive. My thought on that is based on the fact that I think those wipers are just rubber and not something exotic like silicone wipers.
-A
