MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
tyguyc wrote: 05 Nov 2019, 10:04
MoVolvos wrote: 04 Nov 2019, 16:28
tyguyc wrote: 04 Nov 2019, 13:13 Finally cleaned off my radio knob with hand sanitizer. So. Much. Better.
Did it have the sticky coating and if so were you able to completely remove it?
Indeed. and also Indeed.
I used purell, not that it really matters. and took two paper towels to get everything off my fingers.
OK, Got It. GLOVES! Thanks.
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
If you wanted to avoid the gloves, doing it near a sink may be a smart move. that way you can just wash your hands after.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
tyguyc
Post by tyguyc »
E Showell wrote: 05 Nov 2019, 13:25 If you use Akebono ceramic brake pads you will practically never have to clean your wheels again (at least not of brake dust).
But what if you like cleaning the brake dust off your rims? What produces the most brake dust? and wont chew through rotors?
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
tyguyc wrote: 05 Nov 2019, 13:41
My Spanish made Bosch pads certainly seem to do the trick so far :D
ATE Ceramic pads are on the list for next time anything needs replacement. Or by spring. Depends a bit on how long I think I'll keep the car. Though there really isn't anything wrong with it and anything to match it's power/weight ratio is going to be either expensive or as old.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Started LCA, Ball joint, Inner & Outer tie rods today on my '06 V70. Went with all Lemforder parts except inner tie rods (TRW). Broke down one side, taking the struts out will make job a little more roomier. Rear LCA (hockey puck) bushing shot, as well as tie rod end. I think I read somebody used 2" PVC pipe for installing ball joint, it does fit perfectly over ball joints boot protector sleeve. With one threaded end and 2" threaded galvanized cap for pounding on, it just might work.
Has thanked: 1614 times
Been thanked: 4078 times
Press available up in the North Country if you get stuck (or your balls, I mean, Ball joints)
Route 32, just South of Albany
GlennG2759
Thanks abscate, I'm about 50 mins. south of you and I might take you up on that. I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
MoVolvos
Post by MoVolvos »
GlennG2759 wrote: 06 Nov 2019, 15:45 I just sent my daughter to get parts for PVC try. I'll let you know.
Glenn
Great job Dad, teaching your daughter to be handy!
GlennG2759
Iinstalled new ball joints in steering knuckles on my '06 V70. Used 2" by 4" galvanized pipe with cap, worked perfect. About half dozen shots with a 5 lb. hammer and they were home.
