2005 XC70 - Convert to FWD Topic is solved
This topic is in the MVS Volvo Repair Database » AWD to FWD Conversion on a 2005 XC70
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If that's the case you won't have any trouble with using the RHS axle.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
Here's a couple pics of the shaft installed without bevel gearbox. The picture shows a couple hose clamps used as insurance in case the sleeve wanders. It was jammed tight in the gearbox, so I just left it be rather than remove it to R&R the seals. If seals leak, then I'll be forced to revisit the area.
What's the thoughts on the oil at the bottom of the turbo? PCV system maintenance required? I'm planning a big "stage zero" soon, and that's one of the main areas of concern, along with timing belt.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
renns
Post by renns »
All is good. No codes have been set so far, in the first 50 km at least! The older V70 is being retired this weekend, so the XC70 will take over daily driver duties on Monday. My initial concern was codes being set that would prevent the car from passing emissions and/or safety check. There were no issues on that front, and the car is now registered.
jar240
Year and Model: 2006 XC70
Post by jar240 »
Resurrecting an old thread, but renns, I'm wanting to do the same. How has this mod held up for you over the last 2 years?
Thanks
renns
Post by renns »
Sorry, just tripped over this old thread now. I ended up eventually sourcing a replacement bevel gearbox, and getting the AWD system functioning properly again. I ran the car in 2wd mode for several months though, with no issues other than obvious lack of AWD. Given our Canadian winters, it's very nice to have it functional though!
jar240
Post by jar240 »
I'm in the same boat, although the problem is the AWD pump -- difficult to replace with the driveshaft flange/harmonic dampener in the way.
Thanks for the reply...
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
deleted duplicate post
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
greg850r
Post by greg850r »
renns wrote: 31 Mar 2016, 11:09
I don't think this is true. The RHS driveshaft I removed from my '05 XC passes right through the bevel gearbox, engaging in the transmission in the same fashion as my old '98 V70 AWD. I'm going to stick that driveshaft back into place tonight when I get a chance to reassemble the car. I'll add some pics later to further document this process.
Renns, I concur. I just had my 2005 XC70 apart and the RH front shaft is driven from the inside of the transmission by the splines on the end of the shaft. It slides right through the angle gear shaft with no mechanical connection to it. I will unfortunately have mine apart again real soon so I can double check in case I'm remembering this wrong. viewtopic.php?f=9&t=91078&p=522262#p522262
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Jar240, read over Greg's thread, which I think he linked. I'd just replace the DEM pump if you are positive that's what's failed on yours. It really doesn't make sense to remove your bevel gear & driveshaft just to eliminate your RWD over a $290 pump.
Greg, I keep thinking about your situation & I keep coming back to the DEM pump as a possibility. I'd absolutely rule that out before you take a shot at welding your BG to your collar sleeve. Me thinks there's not a whole lot of room for error with that undertaking.
Have you removed the BG again since you replaced the sleeve for round 2 inspection?
On the driveshaft/rear cv joint removal topic -
I've actually been contemplating making 90 or 45-degree M6/8 grease zerk I can fit into the rear of the oscillation damper. Pump grease in a couple holes, drive around a while, pull bolts, see if it'll budge, if not, drive around (close to home!) with bolts removed etc.. a lot like trying to get a seized dually inner wheel unseized from the hub. Maybe leave 2 of the bolts just backed out a couple turns for safety type deal.
I've only really had a struggle with removing 2 rear CV's from the oscillation damper. But going forward I'm thinking I'll force grease into the oscillation damper flange a week or two prior to attempting disassembly on known stubborn subjects.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
greg850r
Post by greg850r »
- Pete - wrote: 06 Nov 2019, 23:15 Jar240, read over Greg's thread, which I think he linked. I'd just replace the DEM pump if you are positive that's what's failed on yours. It really doesn't make sense to remove your bevel gear & driveshaft just to eliminate your RWD over a $290 pump.
Pete, the pump seems to be working.
Other things are breaking faster than I can fix them right now, so round 2 inspection has to wait because I can't tie up the lift that long. If I get it apart and the collar splines are damaged like I suspect they are I won't have a choice but to weld it. The good news is the job falls into the easy category for my neighbor's shop, I already showed it to him along with the utube video of one being done and he thinks he has a way to improve on what others have done.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
