Rear Quarter Window Replacement
rolvo
Year and Model: 2006 V70
Post by rolvo »
Suffered my first car prowl last weekend. The driver side rear quarter window (the one with the antenna) was smashed. I was hoping to find one at a junkyard and attempt this repair myself.
Does anyone have any tips on this job? I'm also wondering if the same window from any 2001-2007 v70 would work? I'm not too concerned about the radio antenna.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
There are two different part number sets for the rear side windows.
The part numbers change at chassis number 118029 ( - 118028 Δ 118029 - ). Don't know what the difference is.
The chassis number is the last six digits of the VIN number.
Get the glass from a 2001-2007 V70 or XC70 in Same chassis number group as your V70.
You will need new trim.
The Antenna on that window is for Road Traffic Information (RTI) & TV.
Active
Past
rolvo
Post by rolvo »
Thanks for the help on this.
There is one more thing I'm trying to understand. The window has a rubber moulding/seal that goes around the complete outside edge of the glass. I had thought this was the trim piece, but looking at the trim piece in online catalogs, it simply looks like an overlay which borders the top and forward side of the window. So the question is if the glass comes with the rubber moulding/seal? I don't see any other seals in the Vida part diagram, so thinking the glass comes with the rubber seal already attached and then the trim is separately glued onto the window after being painted?
RickHaleParker
On the P80 V70s you removed the trim. The glass and rubber seal is just pressed in. Glass and seal came out as a unit.
You have a P2 V70 ... I would think it comes out the same way as a P80 but I cannot say it does.
Active
Past
rolvo
Post by rolvo »
That's what it seems like from what I can tell. The glass/rubber seal is included in the 30674476 part number. The trim is a different part. I'll go ahead and order online. Appreciate the help!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It is a good start to do it first at the junk yard - no stress and can repeat it several times for trickier jobs
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
RickHaleParker wrote: 06 Nov 2019, 10:27 On the P80 V70s you removed the trim. The glass and rubber seal is just pressed in. Glass and seal came out as a unit.
Is this true for 850s also? I have one ready to scrap but was thinking about saving the quarter glass if it isn't too difficult.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
greg850r wrote: 06 Nov 2019, 19:02
Could be similar to the quarter glass for the S70. Remove trim if any and use a piano wire (glass removal tool) to slice the old window adhesive. Clean, prime and apply adhesive. I've replaced a windshield on a 78 Cougar XR7 with my friend who worked at a glass shop and have watched a few windshield replacements up close.
viewtopic.php?f=1&t=71174
https://www.amazon.com/3M-08609-Window- ... 130&sr=8-5
RickHaleParker
greg850r wrote: 06 Nov 2019, 19:02 Is this true for 850s also? I have one ready to scrap but was thinking about saving the quarter glass if it isn't too difficult.
According to Robert Spinner it is true for 850, V70, and XC70 cars from 1993 to 2000.
Active
Past
