Poll to go with 1999 T5V70M56 road incident report, misfiring ( read thread first)
1999 V70T5M56 ignition problem poll
Poll ended at 14 Nov 2019, 05:28
Bad ignition coil(s)
1
17%
Valve problem
0
No votes
Primary wiring fault
2
33%
Bad ground coil to ECU
2
33%
Bad ECU
0
No votes
Bad Iowa wheel bearing
0
No votes
No parking brake
1
17%
Reseat ECU
0
No votes
Bad other part or workmanship
0
No votes
Total votes: 6
Been thanked: 4068 times
You need to read this thread before selecting your option here
viewtopic.php?f=1&t=91347#p523182
or
Recap: I had a symptomatic slight miss at idle, which turned into a constant miss at speed, pulled over on highway, replaced with used coil, all well. Cylinder 2 code misfire popped, and coil 2 replaced.
Once home, I pulled plugs, checked coil bolt tightness, changed plugs for Volvo ones (24k on old)all well
Drove two trips to Boston and one to NJ, total about 900 miles, no problems,
Departing on trip, constant misfire came back at idle and medium load, car runs on 5 at speed with occasional misfire. Flashing CEL light, exhaust smell, and P0302 Po352 codes set.
Bachelors level troubleshooting
Replaced coil with tested spare, did not solve problem. Took car home and took P2
Masters level Troubleshooting
Started car, smooth idle
As car warms, miss in cylinder 2 develops. As I manipulate wires, which are in medium condition, I seem to generate/ stop miss but it is not definitive. I am unconvinced it is a wiring fault in the harness. We swap coils 1 and 2 and problem does not move.
PhD troubleshooting
When you get stuck, you go full bore diagnostic
Step 1: Ignore prior history and get the data
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
That 20 lines down thing disqualified me! So I go with a parking break issue :lol: as we all know that gives an automatic misfire :lol: :?: :mrgreen: June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June wrote: 07 Nov 2019, 07:56 That 20 lines down thing disqualified me! So I go with a parking break issue :lol: as we all know that gives an automatic misfire :lol: :?: :mrgreen: June
You can go back and vote your conscience. I like to think I would have caught this one, but wizechtmgr caught it first.
Extraoardinary Spark Plug Nempathic Skills, AKA ESPN
You have to have daughters or a Miata to know this scene
Screen Shot 2019-11-07 at 11.27.46 AM.png (479.95 KiB) Viewed 1666 times
