I installed a new idle air control valve hoping to fix it..both old valve and new check out fine. Anyways I can plug the idle air control valve in when the car is cold and it won't let me put it in reverse or drive without stalling..park and neutral I get a steady 1000 Rpms..when warm I can feather the gas and take off but not when cold. When slowing to a light I can stop and a second later the Rpms drop to zero.
Now with the idle air control valve disconnected it'll die from cold at idle in park or neutral until warmed up and then I can drive it normally but gas mileage suffers. So I usually warm it up with the iac plugged in and unplug it when warmed up..or else I keep the iac plugged in and throw it into neutral at every stoplight.
I'm thinking a sensor..maybe the temp sensor located under the thermostat..but not sure..gonna test it when cold and warm tomorrow. It's getting cold here in Ohio and it takes awhile to warm this thing up..thanks!
850 stalls when slowing down to a light or in gear except when I disconnect the iac
mescalinedreamz
- Year and Model: 850 t5 1997
- RickHaleParker
- Been thanked: 977 times
Leaks in the Air Intake.
Active
Past
Past
- misha
- Has thanked: 155 times
- Been thanked: 432 times
+1.
If it idles with iac disconnected it pulls air from somewhere else.
When iac is connected it have more air than needed and this choke the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mescalinedreamz
Vacuum guage has never changed..always showed 19 at idle. I will try to spray the engine with choke cleaner hoping for a raise in idle.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
You'll want to check for unmetered air - so anything after the MAF. Check ALL of the intake hosing and associated clamps, you might need to smoke test the intercooler if you have a turbo setup.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
Order silicone lines and replace every vacuum line you can find. If they don't solve this problem it will head off your next one.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 789 Views
Last post by MadeInJapan
- 1863 Views
Last post by DePonce
- 2214 Views
Last post by SuperHerman
- 739 Views
Last post by RickHaleParker
- 847 Views
Last post by davidcschulte
