Indeed and good trick to know cn90.cn90 wrote: 23 Oct 2019, 14:10 Re brake fluid dripping...
In the BMW X5 I mentioned above, I used a piece of wood to press the brake pedal halfway down. This will stop brake fluid from dripping. Good trick!
Making progress with PB treatment at the junction - day 5. The suggestion to cut off the rubber hose close enough to fit a socket (14mm) sounds reasonable.
Since the passenger's side hex at either connector is deformed a little, as Tonyx points out -- see pix above -- should it be filed a little and straightened for socket to fit firmly?
The driver's side is untouched, so, I'll start with this side.
