My 95 850 Turbo has an OBD2 port under the coin tray as well as the old Im guessing OBD1 system under the hood. I've recently learned the diagnostic merits of using fuel trims to narrow down issues, so I'd like to throw out a couple of questions:
1) even though there's an OBD2 port on my 95, is it fully OBD2 - will it display fuel trims if i connect it to an appropriate scan tool (i dont own one or I'd have tried it)?
2) alternatively, i do have a handheld oscilloscope (Hantek 2D82). Can i connect it to my front O2 sensor and use that O2 signal pattern as an alternative to reading fuel trims (the voltage waveform directly from the O2 should show whether its running rich, lean, or neither)?
95 850 Turbo fuel trim, or alternative to.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I would plug in to the OBD2 port and try to read them. If it's there it probably works.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 312 times
- Been thanked: 818 times
Yes, it is fully OBD2.Nick777 wrote: 12 Nov 2019, 13:20 My 95 850 Turbo has an OBD2 port under the coin tray as well as the old Im guessing OBD1 system under the hood. I've recently learned the diagnostic merits of using fuel trims to narrow down issues, so I'd like to throw out a couple of questions:
