2004 S60 instrument cluster issue
Dave in Maine
Year and Model: 2009 S60 2.5T
Been thanked: 3 times
Post by Dave in Maine »
I got a lead on a 2004 S60 which, the present owner complains, the instrument cluster goes blank while driving down the road - the speedo, etc. don'twork. Then they come back on. All while driving down the road.
I had a similar problem with my 96 850 and what it was, was the ignition switch. change that out and all was well.
Does the 04 S60 have the similar issue/similar cause/similar fix?
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
In your case can be one from two things: DIM or CEM. Depends on details of issue.
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
Same thing happened to my 03 V70, sent DIM to electronics house for reflow, $200.
yagger
Post by yagger »
2003 and 2004 MY can be different things.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Indeed, do first the CEM test - flashlight see if there's water traces over the CEM box - under the dash drivers side. Xemodex $$ does it and perhaps Ebay repair services but it's not easy to remove the module (Youtube)
The DIM was mainly 01-03 and perhaps early 04 but it would not really act like that - it would go off, but not come back while driving
Also test the alternator voltage
Dave in Maine
I'm new to the S60 and just considering whether to buy one. What is a CEM? What is a DIM?
yagger
Post by yagger »
Supergrunged
Year and Model: 2005 S60R
Has thanked: 3 times
Been thanked: 4 times
Post by Supergrunged »
I have a 2003 V70, that based on the chassis number, was the last of the cars that utilized the ignition switch. It also doesn't have a PEM, which by P80 terms, that was the fuel pump relay.
The DIM needs to be sent out to be refloated, it's not just a simple fix. Xemodex seem to be the go to for their services. And you can't just swap the DIM, as the millage stays with the DIM
Been thanked: 4068 times
Supergrunged wrote: 18 Nov 2019, 02:26 I have a 2003 V70, that based on the chassis number, was the last of the cars that utilized the ignition switch. It also doesn't have a PEM, which by P80 terms, that was the fuel pump relay.
I don’t think that’s right. When the P2 chassis hit, everything went CEM and PEM for fuel delivery
Can anyone confirm or are there reallybastard P2s?
Supergrunged
abscate wrote: 18 Nov 2019, 03:56
There are bastard P2s.... Why do you think 2001-2002 had a different throttle body then the rest? Yes, they had a CEM But everything was based off chassis numbers, not year, why the dealer asks for your VIN, to get the chassis number. The early years of Volvo P2 before the CANBUS updates in late 04-05 are a mash. Why people always say go 05+
