I had the thermostat fail on my 850T. It gave the usual symptoms - failure to warm up much. It would warm up, just in 45 minutes, and would be giving me heat by the time I got to work.
I finally got the replacement part, and found that rather than the wax failing (as expected), the bracket holding the element had actually broken. I haven't seen one fail this way before, so I thought I'd share.
Roger
Thermostat failure
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
Which brand thermostat was that Roger?
- Roger_850T
That was a Volvo thermostat. (Says Volvo on the bottom, and Wahler on the top.)
To not be too hard on Volvo, it may be that it's never been changed. I checked my records, and while I replaced hoses and coolant along the way, I didn't explicitly write down that I changed the thermostat. On the one hand, I can't imagine that I didn't, but on the other hand, I'm usually pretty good at writing these things down in the log. So, it's possible it has >300k miles on it.
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- Has thanked: 311 times
- Been thanked: 817 times
They all will eventually break, you're not being too hard on it. Good news it broke open, like they are supposed to.
