Vida 2014D Times out 12/31/2017 23:59 Topic is solved
JoseBQ
Year and Model: 2009 XC60
Post by JoseBQ »
RickHaleParker wrote: 17 Sep 2019, 19:16
JoseBQ wrote: 17 Sep 2019, 07:27 By the way, when running DICE test, I get an interface test failure.
Be more specific, what failed ?
Did you use the standalone DiCE diagnostics or the DiCE diagnostics in VIDA?
I already solved the problem following the indications in another thread. It was related to the windows register.
VIDA didn't recognize the DICE, and when performing DICE tests, it gave "interface test failure".
h2do
Year and Model: xc60 2010
Post by h2do »
Is that VIDA2014D_RePack.iso, be available to download somewhere ?
H
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
h2do wrote: 16 Nov 2019, 02:59 Is that VIDA2014D_RePack.iso, be available to download somewhere ?
Download Instructions: Page 16
Install instructions: Page 6.
2099 Patch: Page 1.
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Was the link fixed? I believe the last time I checked, it was dead.
h2do
Post by h2do »
With help istructions on page 16. i download vida torrent, but vida dont install yet. Say after 3min vida not ok. Vida monitor missing etc
RickHaleParker
h2do wrote: 16 Nov 2019, 10:53 With help istructions on page 16. i download vida torrent, but vida dont install yet. Say after 3min vida not ok. Vida monitor missing etc
Sounds like a SQL configuration error.
1. .net framework 3.5 installed?
2. Did you run scripts 1-3, then 2099 patch, then script 4 but not 5?
3. Did you select the Vida all in one option?
It does look like you missed script #4.
Active
Past
RickHaleParker
bmdubya1198 wrote: 16 Nov 2019, 08:30 Was the link fixed? I believe the last time I checked, it was dead.
The hyperlinks are dead but you can still copy and paste the magnet link directly into a bittorrent client.
magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d
Active
Past
h2do
Post by h2do »
Framework is ok. Problem coming in scipt 2 vida not install end.. i think :) yes i think also ist sql problem. tomorrow i delete all and try again.
Here is few line log:
2019-11-17 10:20:56 [INFO] [install.doinstall.3pp.components.is.sqlexpress.installed] Service MSSQL$Vida is not installed.
2019-11-17 10:22:30 [INFO] [install.doinstall] install.doinstall.vida Never started because it's predecessor failed!
2019-11-17 10:22:30 [INFO] [install.doinstall] install.doinstall.databases Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.desktop.shortcuts Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.config Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.autostart.items Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.eswdl Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.Add.InternetExplorer.registry.key Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.add.accesscontrol.to.install.root Never started because it's predecessor failed!
2019-11-17 10:22:31 [INFO] [install.doinstall] install.doinstall.Add.EnableIEHosting.x64.registry.key Never started because it's predecessor failed!
2019-11-17 10:22:32 [INFO] [install.doinstall] install.doinstall.copy.uninstall Never started because it's predecessor failed!
2019-11-17 10:22:32 [INFO] [install.doinstall] install.doinstall.remove.readonly.attribute Never started because it's predecessor failed!
2019-11-17 10:22:32 [ERROR] [install.doinstall] [FINISHED] [NOK] [TOTAL TIME: 00:01:38.1723164]
System.ApplicationException: Error while running vida.doinstall.xml ---> System.ApplicationException: install.doinstall failed!
kohteessa alba.core.tasks.RunFromXML.Start(String ParentTaskName, Hashtable parameters, Boolean overrideRunAttribute, String overrideCriticalAttribute)
--- Sisäisen poikkeuksen pinon jäljityksen loppu ---
kohteessa alba.core.WorkerThread.start()
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
xHeart wrote: 06 Mar 2019, 09:02
Thanks again Rick!
VIDA/DiCE is working. As jimmy57 would say, she has no choice but to work with me -- screen shot is coming.
OK. The Windows 7 end of life is fast approaching. I'm running VIDA 2014D in Windows 7 Ultimate environment.
Would a download and UPGRADE to Windows 10 Pro seamless -- uninterrupted VIDA/DiCE use. OR will it require uninstall and then a clean install VIDA/DiCE?
RickHaleParker
xHeart wrote: 06 Mar 2019, 09:02 Would a download and UPGRADE to Windows 10 Pro seamless -- uninterrupted VIDA/DiCE use.
You might need to install .net framework 3.5 from Windows features.
You might need to reinstall 2014D_RePack, to get all the configurations right.
Follow the install instruction on page #6. Just install over the current install.
Active
Past
