No oil pressure. Stop safely
eamonnpetty
Year and Model: 2009 Volvo S60 2.5t
Post by eamonnpetty »
I’ve been having a warning labeled “no oil pressure stop safely” while taking sharp turns. The car runs and drive fine but I’ve had this warning pop up only while taking sharp turns about three times within the past month. It goes away immediately after straightening the wheel. Any ideas?
Has thanked: 1502 times
Been thanked: 3817 times
Check your oil level of course
It could be your oil pickup is sludged and you are losing oil pressure on slosh. The pan needs to be dropped to confirm and replace parts and all Orings , of course
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
You're more than a little low on oil probably. I've tried myself.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Power steering pump dragging the engine down.
marcus
Year and Model: S60 2002
Has thanked: 12 times
Post by marcus »
Unfortunatelly I had the same situation you are describing. I ignored it. After a while bearing on shaft was rotated. Atfer I had taken down the oil sump I found that the seals were hard and no more flexible. But I do not know why only on sharp turns the light was coming on.
marcus
Post by marcus »
RickHaleParker
1. Open the hood
2. Start engine.
3. Turn the wheels from extreme left to extreme right as you listen to the engine and watch the Tachometer.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
There's an improved pickup tube that goes deeper into pan: 30650552. It needs two longer bolts 982777.
