I noticed after taking the car for a test drive the coolant fan is not coming on and the temp gauge was right at the halfway mark almost.Before i done all the work on it that it would come on even if i only started and ran the car for 1 minute and the fan would stay on for a minute or 2, now i can run it 10 minutes straight and no radiator fan response, any ideas, i double checked my plugs and wiring.
One other thing i forgot to mention, the low coolant light is staying on as well now and coolant is full.
Cooling Fan not coming on
- subzerocarfanatic
- Year and Model: 2000 Volvo C70 HT
- Has thanked: 75 times
- Been thanked: 10 times
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
The fan only runs when the coolant temperature justifies it. I don't remember the exact value that triggers it. Most normal day-to-day driving with decent airflow won't make the fan come on. The fan will always turn on with the AC though, so you can try that to see if it works at all.
As far as the coolant level light, you likely just need to replace the level sensor at the bottom of the reservoir. Or you could just jiggle the float inside the tank and see if maybe it's simply stuck.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- subzerocarfanatic
Ok, thanks for the input, i will try that.
- subzerocarfanatic
I turned on the AC and the cooling fan is still not engaging. It ran before all the work was done, more than it should have probably, considering that even if i started the car then turned it right back off the fan would come on soon as the car was turned off.Now no fan at all, go figure, lol
- RickHaleParker
- Been thanked: 977 times
1. Disconnect the Engine coolant temperature (ECT) sensor.
2. Place a 150 -170 Ω resistor across the wiring harness.
3. Start engine see if the fan is running.
184 Ω = 100 °C (212°F).
170 - 150 Ω corresponds with a temperatures greater then 100 °C (212°F) .
Active
Past
Past
- subzerocarfanatic
This is why i love this site, you guys are Very Volvo fluent! very knowledgeable! where can i get a 150 ohm resistor at sir.....
Red Red black if I remember by Horowitz and Hill
Sadface - we used to go to Radio Shack, now all stores are Taco Bell Amazon
Probably cost about a nickel, with $5.99 for shipping
..One of my favorite Geek Cartoons
- Screen Shot 2019-11-21 at 8.21.51 PM.png (269.78 KiB) Viewed 1268 times
- subzerocarfanatic
Yeah, we no longer have a radio shack here, even though they were pricey you could almost always find the parts to fix most anything, is there any way to dip it in really hot water to try to make it come on so i know if it's bad, it worked before so i'm kinda puzzled.
- subzerocarfanatic
Well.... i have my cooling fan back working, not sure exactly what it was i pulled apart the coolant temp sensor plug and cleaned it with CRC Electric cleaner and double checked fan relay plug at radiator area and when i started it yesterday the fan is working normal, or it's working i will put it that way, to me it doesn't seem normal for it to kick on after only running the car for 2 minutes, not even long enough for Tstat to open up, but soon as i started it the cooling fan came on and stayed on after i turned engine off it stayed on for at est 1 or 2 minutes. Way it did when i bought it.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
It probably thinks the temps are too high when they are not.
- 970 Views
Last post by Pilot9302
- 1445 Views
Last post by chrism
- 22 Replies
- 7518 Views
Last post by sleddriver
- 777 Views
Last post by Vovo_merz
- 1570 Views
Last post by Py
