2001 S-80; 2001 XC-70 Body/Door Interchange
PixelDust
Year and Model: '01 V-70 XC, '84 244
Has thanked: 18 times
Post by PixelDust »
My goal at the scrapyard today:
Find a Driver's Door for my 2001 XC 70 w/Silver Mystic Metallic paint code *426.
One major problem, the only matching paint code at the scrapyard was from a 2001 S-80 Sedan. I had to walk the Entire yard to find this out, apparently they don't inventory their products with the paint code in mind 🀬
No information regarding interchange on these forums, nothing on the internet entirely, the Volvo parts department closed, and the parts counter gurus with their trusty Car-Part Pro software assured me that these vehicles wouldn't match. Couldn't match, impossible, never, no way.
Well, they looked exactly the same to me. So, I measured the dimensions of the S-80 door after carrying it to the counter from deep in the yard. All the components (brackets, electrical, handles, etc) were an exact match except the door speaker.
I then went out to the parking lot, measured the XC-70, and to my delight, all measurements were exactly the same. However, to install the door trim, the speakers had to be swapped. The S-80 has a bulkier speaker housing. I suppose you could cut-it-to-fit as well. I didn't wanna hack it up, so I drilled out the rivets (really annoying, VOLVO), and made the door swap.
The door fit perfectly. The clerk at the counter gave me an excellent deal costing me only 56 REAL U.S. Pesos. He witnessed and participated in the struggle, so I think he felt bad.
All is well now, and the moral of the story, children:
P-2 S-80 Sedan Doors (front, and rear) are compatible with P-2 XC 70 Wagons. Just don't go trying to swap a Boot Lid for a Hatch πŸ˜†
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
PixelDust wrote: 17 Nov 2019, 19:31 P-2 S-80 Sedan Doors (front, and rear) are compatible with P-2 XC 70 Wagons. Just don't go trying to swap a Boot Lid for a Hatch πŸ˜†
On the P80s the front clip and the doors are interchangeble.
Go back and get the S80 front clip and see if this holds true for the P2s. :wink:
Active
Past
PixelDust
Post by PixelDust »
Front clip? Which clip are you referring to? Trim panel clips?
RickHaleParker
PixelDust wrote: 17 Nov 2019, 20:17 Front clip? Which clip are you referring to? Trim panel clips?
Front Clip: The entire front portion of the car forward of the doors. Fenders, hood, wheel wells, bumper, grill as a unit.
Active
Past
Has thanked: 1613 times
Been thanked: 4077 times
...or just go to Volvo web store, pull the body part section up for the XC, then click the fitment tab and look for S80
All while sitting at home cleaning your purge valve
PixelDust
Post by PixelDust »
Copy that. Thanks for your replies.
PixelDust
Post by PixelDust »
Hey, this resource wasn't known. Thanks for that.
..a resource of someone who has actually done the swap wasn't known, now IS known, and is just as valuable!!!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Correction, the rear doors are NOT the same on the S60/S80 vs V70/XC70. Good to edit the comment
PixelDust
Post by PixelDust »
I don't know... The rear doors look like they're exactly the same as well. Here's a photo of the junkyard S-80's door on my XC-70.
oragex wrote: 19 Nov 2019, 15:12
