How do you say goodbye? - S70, not passing NYS emissions...P0444 P0133 Sporadic
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
it kinda amazes me there are no solutions out there to fix a problematic OBD reading. Wait, VW found something, maybe they are willing to share their knowledge ...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Clemens wrote: 17 Nov 2019, 15:14 it kinda amazes me there are no solutions out there to fix a problematic OBD reading. Wait, VW found something, maybe they are willing to share their knowledge ...
M...I’m stripping off the evap system too, so will have parts
Marco, those two codes are disabling theECM checks of the other systems, so you won’t get readiness.EFI-541 (P0444) Canister purge (CP) valve, signal
Condition
Diagnostic trouble code (DTC) EFI-541 (Canister purge (CP) valve, signal) is stored if the engine control module (ECM) registers a fault in the canister purge (CP) valve coil or cables after 5 seconds.
Substitute value
2-heated oxygen sensor (HO2S) control disabled
the electrical test of the front heated oxygen sensor (HO2S) is disabled
the electrical test of the rear heated oxygen sensor (HO2S) is disabled
the pulsed secondary air injection system (PAIR) test is disabled
the heated oxygen sensor (HO2S) test is disabled
the three-way catalytic converter (TWC) test is disabled
leak diagnostic disabled
fuel shut-off conditions changed.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
But how? Why aren't those codes just coming on? I got out work too late (and it's too cold) to check out this fuse...
Retired:
2015 Volvo S60, T5, 85K
- theWIFES_S70
Maybe this car wants to break up with me?
Retired:
The engine management is complex, it’s not just looking for signals,
To pop a misfire code , for example, P0303 for cylinder 3 misfire, it has to be detected over a certain interval for at least a certain number of revolutions.
If the evap system can’t complete, it tries twice more during your drive , then gives up until the next one. The code will show pending, but the CEL won’t come on because the cycle didn’t complete
- RickHaleParker
- Been thanked: 977 times
She is just playing for attention. You spend too much time working on something else.
Active
Past
Past
- theWIFES_S70
RickHaleParker wrote: 17 Nov 2019, 20:05She is just playing for attention. You spend too much time working on something else.![]()
Retired:
- theWIFES_S70
What sucks is that in NYS, if I take it to a shop and am charged over $400 for check engine repairs (during inspection), they can push through the inspection. (I just looked this up today.) But there's no check engine light... So no codes are triggering. So frustrating. I did have p0442 and P0133 codes pending for a few minutes as I kept scanning for I/M readiness. But when I rescanned the engine a half hour later, they were gone.abscate wrote: 17 Nov 2019, 19:12 The engine management is complex, it’s not just looking for signals,
So,
- check fuse
- replace purge valve
- replace front o2 sensor
Anything else?
Retired:
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Using VIDA you can force the evap test to run at your will =)
- 12 Replies
- 2871 Views
Last post by matthew1
- 9 Replies
- 1306 Views
Last post by Jonboy74
- 1520 Views
Last post by 1998-S90-Owner
- 553 Views
Last post by jjmtjordan
- 1909 Views
Last post by alschnertz
