2000 C70 HT 2.3 3rd Brake Light
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
Well it seems Volvo wants you to replace the entire brake light assembly when it goes out,I love the craftsmanship that went in to these C70's when they were hand built for however many years they were but this seems absolutely absurd. I took me the better part of an hour to get it out from all the adhesive used to install it and it was attached to the weatherstriping to boot, then i see there is no way to replace a bulb, I assume it's LED but it still could have been made so it can be replaced,now i have yo buy the entire 3rd brake light,I tested it with 12 volts and it does not light up. I will post a few pictures after church this morning.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Take a picture of the pc board on the back of it, I'd be willing to bet a voltage regulator died as I cannot think of any other reason the entire assembly would stop working.
Been thanked: 4065 times
It won’t be LED in year 2000, designed in 1990.
I think it is a one piece unit though.
Google part number for eBay replacement.
subzerocarfanatic
wizechatmgr wrote: 18 Nov 2019, 00:28 Take a picture of the pc board on the back of it, I'd be willing to bet a voltage regulator died as I cannot think of any other reason the entire assembly would stop working.
If i can separate the red lense from backing i will.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I thought the P80 V70 3rd brakelight was LED. What else coulb be that tiny and bright with only 3W (if I remember the value on the V70 bulb indicator assembly correctly)?
1996 855 R,
2010 V70 D5,
subzerocarfanatic
All i know is it has 2 wires going to it and no way to service it,can't be opened to check for a bulb type if any.
