Removed spark plugs from 2006 B5244T motor. Length of thread is 19mm, replacement plugs are 26mm length??? Which is corrrect???
T5 model.
Checked numerous auto parts sites, most show/list a 26mm reach plug....
Thanks
Wrong spark plugs?
Eschew the auto parts figment guides for the user manual recommendation
Volvo or Boschplugs only, please
Ok, IPD site lists a Bosch FR7MPP10 , which is 26mm reach.
Plugs I removed are FR7DP......19mm reach...
Which is right. Car ran for at least 15,000 miles on the short plugs....
Longer plug may hit piston .....
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Do you know the entire history of your car?
Doing a little research, the B5244T motor was shipped with earlier 2.4l engines. I've got a 2001 V70 T5 with a 2.3l engine that uses the 26 mm spark plugs. Could this be a junkyard engine put in your 2006 S60 T5?
Maybe the earlier 2.4l engines used 19 mm plugs?
Are you sure you have a T5?
Or maybe you have the B5244T5 engine? The B5244T5 uses 26mm plugs referenced above by velorider.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Take a look at the Denso website and look up the correct plugs
http://densoautoparts.com/find-my-part. ... rchResults
For a 2006 S60 2.4
IKH20TT
For a 2006 S60 2.5
It depends if you have a T2 or T4
IKH20TT for B5254T4
IK20TT for B5254T2
Spark Plug IK20TT ( 4702 )
Mfr Label Iridium TT
Aspiration Turbocharged
Resistance 5000
Ground Electrode Tip Design Platinum Twin-Tip
Ground Configuration Twin-Tip
Ground Electrode Core Material Nickel
Center Electrode Core Material Copper
Center Electrode Tip Material Iridium Rhodium Alloy
Gap Size 1.0 mm
Ground Electrode Quantity 1
Hex Size 16.0
Manufacturer Heat Range 20
Seat Type Flat
Reach 19.00 mm
Thread Diameter 14.00 mm
Spark Plug IKH20TT ( 4704 )
Resistance 5000
Gap Size 1.0 mm
Hex Size 16.0
Seat Type Flat
Reach 26.50 mm
Good Luck
Paul
For a 2006 S60 2.4
IKH20TT
For a 2006 S60 2.5
IKH20TT for B5254T4
IK20TT for B5254T2
Resistance 5000
Gap Size 1.0 mm
Hex Size 16.0
Seat Type Flat
Reach 19.00 mm
Resistance 5000
Gap Size 1.0 mm
Hex Size 16.0
Seat Type Flat
Reach 26.50 mm
Good Luck
Paul
- pgill
What number is in you VIN position 6 and 7? (YV1 M S ## 2 6 5 2 049843)
http://new.volvocars.com/ownersdocs/200 ... n2006.html
52?
54?
59?
52 = B5254T4 S60/V70 R AWD - Automatic / Manual
54 = B5244T5 S60 T5 FWD - Automatic / Manual
59 = B5254T2 S80/S60/XC90 2.5T FWD/AWD, V70 2.5T FWD, XC70 AWD - Automatic Only
52?
54?
59?
I am not by the car currently. But I will check vin. The tag on the hood listed the engine as “B5244T”
But I did try the denso site. It picks a 26mm reach plug for a 2006,S60,T5, automatic- the denso 4704.
Thanks for your help Paul
- RickHaleParker
- Been thanked: 979 times
Per Bosch:Teeka56 wrote: 18 Nov 2019, 07:22 Ok, IPD site lists a Bosch FR7MPP10 , which is 26mm reach.
The 2.4L can use FR7MPP10 or FR7NI33.
The 2.5L can use FR7MPP10 or FR7DPP+ .
FR7MPP10 is OEM for both.
Run you VIN number through the Bosch parts finder.
Active
Past
Past
- 16 Replies
- 4435 Views
Last post by shiloh51933
- 3302 Views
Last post by ndphotonl
- 1846 Views
Last post by E Showell
- 900 Views
Last post by brickhead
- 797 Views
