Hello, my 2000 V70 headlights are very dim and my power windows are slow to roll up and down. My headlight reflectors look ok, so I suspect there's a power problem robbing them of electricity. The battery is fairly new and fully charged.
How can I check the voltage regulator for proper output? What is the correct output range? How can I check the headlight voltage and what reading should I get? What else might cause decreased electrical output and what could I check to diagnose it?
This problem has been lingering for the past two years. I haven't driven the car much during that time. It seems to drive ok with proper power, gas mileage, etc. Thanks for your help.
Voltage regulator causing dim headlights and slow windows
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Best install a voltage gauge. Or just hook up a multimeter.
You need to check the battery connections, the alternator connections etc. You can lose quite a bit of voltage on the crips on the battery terminals if they aren't that good any more.
The Alternator should put out 14Volt, in idle and during driving. Maybe slightly less.
I had to solder the battery terminals and replace the regulator on my 850 to get it back to ~14v.
850 T5-R '95 auto
- Been thanked: 4068 times
Check the thick red wires feeding the fuse box for corrosion under the crimp, as well as the ground.
With a good battery, the windows should work well with the engine off, so the regulator isn’t the issue here
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
The battery + cable and the B+ cable abscate referred to are both good candidates for your symptoms, and both are common failure points in the electrical system particularly on the '99-00 cars. When my battery cable died it got hot to the touch. You can measure your alternator output easily by measuring at the big cable on the back of the alternator. You should see 13.7-14.1 VDC when running. Measuring voltage drops is easy, and a good way to diagnose which cables/connections are bad. Make sure your battery terminals are clean and tight.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- FireFox31
To test these things, do I put the negative multimeter probe on the battery negative post? That relies on grounding cables, not revealing if the + or - wire is the issue. Sounds like I should start testing at the battery and work my way farther from it.
FireFox31
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Start at the battery and measure wherever you can reach. Check the voltage level and if it's consistent or not. Also both while running and when not. The very first measurement you'll want to do is on the battery when it's been charged then rested a couple of hours, overnight or so.
That’s right. Negative probe direct to the battery postFireFox31 wrote: 20 Nov 2019, 12:27 To test these things, do I put the negative multimeter probe on the battery negative post? That relies on grounding cables, not revealing if the + or - wire is the issue. Sounds like I should start testing at the battery and work my way farther from it.
- FireFox31
I think my alternator may be at fault. After getting into an accident, my battery was too weak to start the car. After the accident, the glove compartment was open with its light on for two hours and the four way flashers were on for over an hour. When I removed the battery to charge it, the charger read about 75% and took about three hours to charge. I had just driven the car 700 miles in four days, so I feel the battery should have been fully charged. I can't imagine some glove box and flasher lights could have drained it that much.
Once I get the body work fixed, I'll revisit this alternator testing. Until then, let's hope I can afford to have the body work repaired (if insurance doesn't pay, which I don't think it will).
FireFox31
That battery is probably just not accepting charge any more. If it’s more than 5 years old, it’s dead, Jim.
- 5583 Views
Last post by hans747
- 640 Views
- 9 Replies
- 4866 Views
Last post by erikv11
- 10 Replies
- 2299 Views
Last post by Atis
- 950 Views
Last post by martin calva
