I bought this Italian spec 850 T-5R and was told by the owner that, because it is an Italian market car it has a 2.0T(b5204t) obviously.. BUT when I went through the service book I noticed somewhere it said that the engine was replaced. So I went to check the code on the engine and it says: B5234T4. According to Wikipedia this is the 850R engine? The engine swap was done in the Netherlands were the 850R is a ‘96 or ‘97 car like almost everywhere else I assume. This engine is supposed to run 250hp according to the specs on Wikipedia. Where it doesn’t feel that quick to me and only builds 7psi of boost I checked the ECU and it seems that it still has the 2.0t ECU installed.. code 0 261 200 548.
I suspect this to be the reason it doesn’t make good power? (Does the 2.0T make such low boost?) I also think they didn’t swap over the turbo that belongs to the B5234T4 but rather placed the B5204T turbo back since it has the 13G fitted
Also I can’t really find reliable information on which ECU this B5234T4 engine is suppose to run. Is it the 4.3 or 4.4 that runs the B5234T4? I’ve read stories that no 850R has the 4.4 originally but also that some might use it..
I of course want to use the full potential of the B5234T4. Installing a 16t and the correct ECU would do that I think. Just like to know which ECU to look for.
Thanks!
