- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
I was under the impression, but ready to be corrected, that one can just swap the skins over (unless it's MY99 in which case they're very different). Can swap the foams too if they're in better nick.
- Has thanked: 316 times
- Been thanked: 531 times
Yes, the seat skins can be transferred over no problem, so long as the donor seat and the old seat are both power/manual due to the seat back being different. Manual seats have a knob for the recliner.
As for the bottom, it's the same regardless of being manual or power.
- 99commutervolvos70
- Year and Model: 1999 S70 GLT
I think I will just try and swap over the skins if I can't find a set just as good. I would prefer to just swap the seats as an assembly, but the Local Junkyards have either the wrong color or worse than the ones I currently have. I just need to buy a hog ring plier set and some hog rings. Thanks for all the suggestions
- Been thanked: 4071 times
You can swap in 1996-1998 skins to the 1999-2000 electronically fired seatair bags just fine
You can attach with zip ties rather than hog rings
If you want to save yourself a “ deskin” you can buy the skins standalone too for about $300 a pair, twoseats
Lseat.com
Lseat.com
Kridder08
- Year and Model: 1998 V70 GLT
- Has thanked: 9 times
Have had my 98 V70 (165k) for about 8 months. Finally got around to pulling the spark plugs. It has ngk platinum plugs - looks like they have been there a while. Can’t get the original Volvo 4 electrode plugs locally. Has anyone tried the Nickel, 4 electrode NAPA plugs?
Stick with either OEM Volvo or Bosch plugs on these cars.
You can get them in a day from FCP inCT in New England, Bosch Cu plugs are about $2 each
NAPA brand are *probably * made by Federal Mogul, a reputable brand?
Yes, zip ties are much easier than hog rings when installing the seat covers. I've done this multiple times, nobody will know the difference!abscate wrote: 23 Nov 2019, 20:28 You can swap in 1996-1998 skins to the 1999-2000 electronically fired seatair bags just fine
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Why are zip ties easier? I've always used hog rings and it's quick and easy.bmdubya1198 wrote: 24 Nov 2019, 07:45Yes, zip ties are much easier than hog rings when installing the seat covers. I've done this multiple times, nobody will know the difference!abscate wrote: 23 Nov 2019, 20:28 You can swap in 1996-1998 skins to the 1999-2000 electronically fired seatair bags just fine
BMW 540i 2002
S70 Base 2000
