Hello! I have a electric fan that is not working and have never done! I have checked the 60a fuse under electric fuse box in the engine bay, i have voltage in the thick cables that go to the fan. I have tried and hooked up another used fan and its not working either.
I have autocom diagnostic so i can activate the fan manualy. It works on other v70 but not mine.
What should i check???
650b electric fan signal missing
- RickHaleParker
- Been thanked: 977 times
Check ground 31/2. It grounds the Fan Control Module and the fan motor.
Active
Past
Past
Hello sir and thanks for your reply! I unbolt the 3 wires, sanded all contact areas and bolted them back again, not any good news. Its the same:( more ideas? And thanks from sweden!!RickHaleParker wrote: 25 Nov 2019, 03:26 Check ground 31/2. It grounds the Fan Control Module and the fan motor.
- 604 Views
Last post by Guesten
- 1397 Views
Last post by Biovince49
- 7655 Views
Last post by julesvern
- 22 Replies
- 2717 Views
Last post by jonesg
- 13 Replies
- 1989 Views
Last post by xHeart
