OK, gentlemen, I may be driving myself nuts for nothing but is the socket where the left hand side, rear fog light resides, supposed to serve a dual purpose? In other words, is it a fog lamp when the switch up front is depressed and should it be a running light when the switch is not depressed?
I ask because in the same exact location on the right side there is a running light that always stays on once the car is started. Is the left side only a fog light?
Left rear fog lamp/Multi-purpose or not?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Yes, there is a single rear red light fog bulb on driver's side, that is supposed to come on by pressing the fog switch. You may also have the daytime running lights that come on always as the car is running - front and rear
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
And if you've got DRL* then yes it's the same 5/15w bulb.oragex wrote: 25 Nov 2019, 12:06 Yes, there is a single rear red light fog bulb on driver's side, that is supposed to come on by pressing the fog switch. You may also have the daytime running lights that come on always as the car is running - front and rear
*Front and rear DRL should be mandatory everywhere. With regards from the safest country in the world to drive.
Mr. Detail
OK, here goes. The bulb that is in this spot/connector is a 7506 Osram/21W.
My question still remains, if I turn off the fog light via the switch up front, should there still be light coming from that same
location? There is light coming from the RHS in that same location but it is dark from the left side once the fog light is turned off.
Mr. Detail
So can anyone suggest a solution? I have replaced the bulb, checked all fuses, pulled the inner trim panel to get access to the rear relay panel and replaced the relay. After all of that, it still does not work. Not sure what to do next.
Mr. Detail
Can anyone else verify that a 7506/21W bulb goes there?
- Has thanked: 1611 times
- Been thanked: 4072 times
There is a level of inattentiveness of drivers here in the US that will astound youRattnalle wrote: 25 Nov 2019, 12:48And if you've got DRL* then yes it's the same 5/15w bulb.oragex wrote: 25 Nov 2019, 12:06 Yes, there is a single rear red light fog bulb on driver's side, that is supposed to come on by pressing the fog switch. You may also have the daytime running lights that come on always as the car is running - front and rear
DRLs mean 1/3 of drivers drive at night with no rear lights on because their dash glows
- 6810 Views
Last post by Rokas13
- 1434 Views
Last post by June
- 884 Views
Last post by Sommerfeldt
- 857 Views
- 1923 Views
Last post by broadusc
